Author Topic: headlight leveling motors removal  (Read 1346 times)
mathewst
  • Split, Croatia
    • v40
« on: 19 May 2009, 08:47:09 »
Got to check these, but want to make sure how to safely remove them cause dont wan to break anything.
What is the easiest and the safest way to do this? Do you just pull them out or they have some way of releasing them?
If anyoune has some tips and has done this I would be really grateful for the advice
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: headlight leveling motors removal
« Reply #1 on: 19 May 2009, 08:49:37 »
If you mean the ones on the back of the headlight then they are a bayonet fitting  :y
Trade club card holder
Code scanner available
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 19 May 2009, 09:30:21 »
Yes Alexandjen those bayonet ones are in need of checking but want to know for sure how to safely remove them
Bumbazor
  • Worksop
« Reply #3 on: 19 May 2009, 09:42:49 »
It will be easier to remove the whole headlight off the car first and then try to remove the motor, than to try to remove the motor while the headlight is still on the car. Visibility will be better and things will be easier to hold.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 19 May 2009, 13:15:37 »
connection to the headlight it a plastic ball joint that 'pops' into the socket on back of light.
Motor twists to release from housing then pull out ball joint but like already said it maybe easier to do with headlight removed.
(in fact i think you'll find lack of space makes it impossible to do without removing headlight :-/)
