Author Topic: Crank sensor  (Read 1973 times)
Vmax
  • Waterlooville, Hampshire.
  • Missing life on two wheels :(
Crank sensor
« on: 19 May 2009, 12:17:48 »
Hello, Does any one have the part number for a Crank Sensor for my 99 2.5 ? Thanks  :y
Keep Calm And Carry On.......
V6Astra F
  • Heidelberg , South Africa
  • 3.2 V6 Powered Kadett
Re: Crank sensor
« Reply #1 on: 19 May 2009, 12:21:32 »
hi
i think its 90458251
Re: Crank sensor
« Reply #2 on: 19 May 2009, 12:29:01 »
Unfortunately you'll have to check it to be certain... There's a few and EPC is often wrong ::) ::) ::)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Crank sensor
« Reply #3 on: 19 May 2009, 12:41:37 »
You will need to check like already said with Vauxhall with your reg number but it will more than likely be the on that is around £57 :y
« Last Edit: 19 May 2009, 12:42:22 by Loo-knee »
Vmax
Re: Crank sensor
« Reply #4 on: 19 May 2009, 13:50:08 »
Thanks folks  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Crank sensor
« Reply #5 on: 19 May 2009, 14:02:10 »
Personally I would have thought you Crank Sensor would be this Part Number  = 90492061 but check first :y
Vmax
Re: Crank sensor
« Reply #6 on: 19 May 2009, 14:04:27 »
Thanks mate, I just called Vaux he doesn't know which of two part numbers it would be  :-/. He said he needs the part number from the sensor. Could I easily see that or is it a strip down job.
ta.  :y
Re: Crank sensor
« Reply #7 on: 19 May 2009, 14:24:41 »
ta.  :y
You can see it by getting your head in there but TBH I'd remove the sensor (leave it plugged in) so you can get a better look. If it's got a metal body (can't remember the P/N off the top of my head) I have one I got slightly cheaper than TC price which you're welcome to purchase :y :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Crank sensor
« Reply #8 on: 19 May 2009, 14:43:14 »
Would have thought the easiest way would be to look at the Crank Sensor connection which will be at the rear of the Plenum.
This is the "Oval" one
Vmax
Re: Crank sensor
« Reply #9 on: 19 May 2009, 15:00:34 »
Great thanks chaps! :)
Re: Crank sensor
« Reply #10 on: 19 May 2009, 15:47:38 »
I couldn't get my shovels in there though :-[ :-[ ::) ::)
Re: Crank sensor
« Reply #11 on: 20 May 2009, 20:19:00 »
Most probably 90492061 - thats the one with plastic fitment on sensor end and oval plug.  Part nş is on bottom of sensor end.  Price on TC £43.04 + VAT  :y
