Author Topic: No Power but no engine management light  (Read 1288 times)
martin3227
« on: 18 May 2009, 21:07:47 »
Can anyone please help just picked up an Omega 2.2  auto on a 02 plate car looks great and everything works as it should HOWEVER there seems to be no power. First i thought it was the gearbox as it didnt seem to kickdown like other autos i have driven but after further use it seems just to be generally lacking power from the start and at the top end. will build up speed slowly and then max around 90 mph. no warning lights and had it to Vauxhall and no error codes was present. have it booked at a local garage on Thursday but open to any suggestions which i could try before hand
Re: No Power but no engine management light
« Reply #1 on: 18 May 2009, 21:08:37 »
Where are you?
martin3227
« Reply #2 on: 18 May 2009, 21:10:24 »
Nr York
« Reply #3 on: 18 May 2009, 21:12:54 »
bugger.
OK, slap it in 1, does it go better then (to 35mph anyway)?
Does the EML come on with ignition, and stay on until engine start (ie, scumbag hasn't wired EML to another light, or removed bulb!).
martin3227
« Reply #4 on: 18 May 2009, 21:22:17 »
Hi Mate,
Light comes on and then goes off when engine has started. Just the same really driving in first (just been out to double check) although as it is held in gear the top end is alittle faster. but not much on the start. no warning lights or error light on at all when engine started and driving.
« Reply #5 on: 18 May 2009, 21:26:47 »
Disconnect the MAF sensor and try it.
martin3227
« Reply #6 on: 18 May 2009, 21:38:20 »
thanks for the advice will try tomorrow when have more light as i am not the best at finding my way around the car especially as it is new. dont want to be un plugging the wrong thing. will consult trusty old haynes manual tomorrow and come back to you
MutantCav
  • Gainsborough
« Reply #7 on: 18 May 2009, 22:36:33 »
Its in the middle of the main air tube that runs from the air box :y
martin3227
« Reply #8 on: 19 May 2009, 19:23:35 »
thanks for the tip...just done that and started car up engine management light came on (higher idle) however i lost control over the accelerator, engine did not respond when pressed.
Reconnected the cable engine management light went out and firt time round accelerator still did not respond. tried again and accelerator now responds...however power still not there :-(
martin3227
« Reply #9 on: 21 May 2009, 12:04:39 »
Hello,
Garaged just called told me  that the engine management light has been disabled (bulb) great isnt it - i was looking at the service light!
cant understand why Vauxhall didnt tell me that...obviously didnt even bother. The garage has pulled of 8 codes in particular accelerator position, sensor is ok but voltage not getting through...he is still investigating.....not sounding very good is it
martin3227
« Reply #10 on: 21 May 2009, 12:38:21 »
Car currently at garage. Engine management light bulb has been removed!! i was looking at the service light - Typical!!
Anyway 8 codes have come off not sure why Vauxhall didnt spot this obviously they didnt even look at it.
Anyway major one that the garage is looking at is the throttle voltage. sensor is ok and is checking the voltage. hope it isnt the ECU :-(
any further posts or anything would be much appriciated - will keep you updated on the final verdict
