Author Topic: 2.5 ECU on 3.0 Engine  (Read 1419 times)
MutantCav
  • Gainsborough
« on: 20 April 2009, 23:32:03 »
Runs fine but what differences will you get from having a 2.5 ECU on a 3.0 engine...if reprogrammed to tell it that its a 3.0 engine will it adjust its values automatically?
Re: 2.5 ECU on 3.0 Engine
« Reply #1 on: 21 April 2009, 00:13:46 »
I'd have thought things like fuel trims will be different - make sure it's not running too lean, you don't want any holes in any valves  ::)
I stand to be corrected, but i'm not sure it's a simple task to reprogram a 2.5 ECU to a 3.0, and vice versa...
« Reply #2 on: 21 April 2009, 10:19:33 »
During most running it will be closed-loop so the mixture should be correct but, of course, flat-out, wide-open throttle running will be open loop, and that's just where you need it NOT to go lean.
In theory, it will see extra airflow through the MAF and provide the correct amount of fuel. In practice, who knows?  :-/
You might find the ignition map is different too, so it will run better, or give better economy, with the correct ECU although the differences through the seat of the pants when driving will be subtle.
As said, you can't reprogram the ECU. Best bet is to get one from a 3.0 if you're concerned. Or get a chip for a 3.0 and put it in the existing ECU assuming the hardware is the same?
« Reply #3 on: 21 April 2009, 10:57:32 »
Both 2.5 and 3.0 ECU's are the same post 1998
MutantCav
  • Gainsborough
« Reply #4 on: 21 May 2009, 21:32:05 »
Both the same ECU but are they the same settings?? If not how will the 2.5 settings affect the 3.0 running?? I can see there are different engine management profiles that you can set up when talking to the ECU but dont seem to be able to change the current 2.5 profile to a 3.0 one
« Last Edit: 21 May 2009, 21:32:26 by ShieldOfSteel »
    • 530D M Sport, 330i Coupe
« Reply #5 on: 21 May 2009, 21:36:28 »
Well when the VVOC lot drop in the 3.0 V6 in place of a 2.5 V6 on the Vectra B they run it on the original ECU - the MAF see's more airflow and the ECU compensates fuelling to match.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 21 May 2009, 22:49:21 »
yep VVOC just use X30XE with a 2.5 Veccy ECU some VVOC members got 3.0 omega Performance chips fitted to there V6s and the power increase was the same as a chipped 3litre would be i think from memory it was TabVec that had his v6 Veccy 3.0 chipped
