Author Topic: Misfire still  (Read 903 times)
megaomega123
Misfire still
« on: 22 May 2009, 08:38:51 »
Have changed coil pack and still have an intermittent misfire. Leads were all tested and their resistences were all within 1ohm of eachother relative to length.
Is it likely to be a spark plug??
The misfire occurs at high revs / low gear and the pick up is slow high gear / low revs.
Dazzler
  • Haverhill, Suffolk
Re: Misfire still
« Reply #1 on: 22 May 2009, 09:02:03 »
Plugs are the cheapest thing to try first and will cause this problem if breaking down.
I personally will always change them first with a fault like this.
