Author Topic: bought myself a 2.2 dti and need help  (Read 2012 times)
tommycon
  • oldham
« on: 11 May 2009, 20:10:53 »
hiya,,
 i managed to get a 02 dti, its been around and looks abit neglected but i plan to get it back to its former glory.
couples of Qs for now if anyone can help.
 the turbo seems to whistle when spooling up and the power delivery as a very slight flat spot, does this mean the turbo unit is on its way out?
any tips on changing the fuel filter,, took a while to find it as its buried under loads of pipes.
i`m sure i`ll be asking more later but any help with these will be most welcome.
 thanks. Paul
Re: bought myself a 2.2 dti and need help
« Reply #1 on: 11 May 2009, 20:57:59 »
hiya,,
 thanks. Paul
Make sure you fill it right up with diesel otherwise you'll never get it started again without full bleeding ::) ::) ::)
waspy
« Reply #2 on: 11 May 2009, 21:04:58 »
The whistle is normal & nothing to worry about. Remove & clean the EGR Valve & Pressure Sensor Switch, that'll make some difference.
As for the filter, yup it's a pain in the arse. I hate doing mine. Be very carefull with the plastic fuels pipes, they're easy to flatten/kink when moved. I'm changing mine to rubber ones when i get in the mood.
tommycon
  • oldham
« Reply #3 on: 11 May 2009, 21:16:58 »
i changed the fuel filter on my 2.2dti vectra and it took ages to start so i`ll make sure i fill it this time thanks , these dont have a priming pump do they, the diesels years ago did, ha ha,
any chance you could tell me where the valve and switch are located please
 put my mind at ease a little over the whistling turbo,, thanks
Stoph
« Reply #4 on: 12 May 2009, 13:31:04 »
Was reading somewhere recently that a turbo only whistles if its out of balance?? I thought they all whistled but maybe its a 'how loud' is ok question... others halfs Primera DCi ate its Turbo last week at 57000 miles... it had always whistled loud enough that you thought there was a police car nearby if on/off the throttle... never thought anything of it till doing research on why it went bang..... My 525 TDS has a silent turbo... and the new one on the primera is silent too :-/ :-/
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 12 May 2009, 18:44:02 »
A slight whistle from the turbo is perfectly normal, especially when accelerating.
It's definately worth checking that all inlet pipework from the air filter to the turbo is correctly and securely fitted. Also check that the air filter is not obstructed in any way, and that the top of it's box is seated correctly to the base.
tommycon
  • oldham
« Reply #6 on: 13 May 2009, 17:55:46 »
replaced the air filter yesterday, it was very dirty, turbo still whistles with new air filter, have the same engine in my vectra and that doesnt whistle at all, did read that it could be loose hoses or split pipes, so i`ll be checking them thanks.
i know the omega is a heavier car but it does seem down on power compared to the vectra
i will be changing the fuel and oil filters too,
 cheers.
 paul
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #7 on: 18 May 2009, 09:09:58 »
you will need a 36mm !! socket and a long extension  for the oil filter and your sump bolt is a star drive
dieseldonicely
tommycon
  • oldham
« Reply #8 on: 18 May 2009, 17:50:13 »
i reckon its the same size as the one on my vectra,, bit more tricky to get tho,, thinking i`ll need a knuckle joint to cope with the angle,, did you?
by star do you mean torx?
 cheers
omegaman2
« Reply #9 on: 22 May 2009, 07:50:05 »
yes torx is what i meant
i made a tool by hammering a 13mm socket into the 1" drive socket thus jamming it solid then just add extension bars to suit 3/8 drive
now its a doddle :y
dieseldonicely
tommycon
  • oldham
« Reply #10 on: 22 May 2009, 17:28:03 »
managed it, i got a set of torx keys, hardest part was get the filter back in passed all the pipes and brackets,, the oil was manky.
 cheersting
