Author Topic: auto box 2.5 v6  (Read 1290 times)
kentguy
  • kent
  • hi
auto box 2.5 v6
« on: 23 May 2009, 12:42:57 »
hi got 2.5 v6 auto just got her got prob with the auto box when you pull away seems to be suck in 3rd when cold all fine s botton comes on. auto Box check comes on dash com but then at times box ok very new to this car cant see why i did not buy one sooner great car would the box need topping up not sure how any advise would been wellcome ty
Re: auto box 2.5 v6
« Reply #1 on: 23 May 2009, 13:00:29 »
you need a fault code reader plugging in to diagnose the fault. Could be the selector switch ....  :-/
Re: auto box 2.5 v6
« Reply #2 on: 23 May 2009, 13:00:46 »
razzo
  • Crapital
    • 97 3.0 Elite
Re: auto box 2.5 v6
« Reply #3 on: 23 May 2009, 13:04:47 »
check fluid level in box, it needs to be at runnng temp, on level ground with engine running, level needs to be at bottom of sump plug hole & use dex 3 if it needs a top up
Re: auto box 2.5 v6
« Reply #4 on: 23 May 2009, 13:04:57 »
Have a gander here http://www.omegaowners.com/forum/YaBB.pl?num=1152783586 :y
IMO it's not an ATF level problem.
Re: auto box 2.5 v6
« Reply #5 on: 23 May 2009, 13:07:16 »
Possibly not, but a good place to start ;)
Re: auto box 2.5 v6
« Reply #6 on: 23 May 2009, 13:09:31 »
Get the dirty jobs over with first?  ;D  ;D  ;D  ;D
