Author Topic: Fault codes help  (Read 1024 times)
bigdods
  • Brackley
Fault codes help
« on: 23 May 2009, 12:14:19 »
Just changed the battery , now have some fault codes would these be as a result of having the power disconnected or something else ? No I didnt check the codes before changing the battery as I am stupid.
Had the cam belt, water pump changed last week plus full service and breather/ICV clean so everything has been disconnected in the last few days while that was done.
Codes as best as I can tell are:
73 Mass Air Flow Sensor Voltage Low
33 Exhaust Gas Recirculation (EGR) Valve Voltage Low
57 Idle Air Control Voltage Low
19 - This i had before so I think its time to change the crank sensor !
Suspicious that all the codes are low voltage, maybe theres a connector loose somewhere ?
Car runs fine, EML doesnt come on when running.
« Last Edit: 23 May 2009, 12:14:51 by bigdods »
Re: Fault codes help
« Reply #1 on: 23 May 2009, 13:34:37 »
I'm in all day, feel free to pop it up, we'll clear 'em all out again, then you can paperclip it in a few days.  Possibly caused by the battery always going flat ;D
bigdods
  • Brackley
« Reply #2 on: 23 May 2009, 18:33:15 »
cheers , just got back in, I'll pop round in a minute see if you are still in ;-)
