Author Topic: rear door windows  (Read 1589 times)
kjf7
  • lincolnshire
rear door windows
« on: 14 May 2009, 22:40:55 »
whats the best way to remove these inc quater light without damage? changed the doors and old windows have codes engraved into them same as others on car would'nt bother otherwise.
« Last Edit: 14 May 2009, 22:46:16 by kjfomega »
Bumbazor
  • Worksop
Re: rear door windows
« Reply #1 on: 15 May 2009, 08:43:28 »
I haven't looked myself but I'd start by removing the rubber seals around the window. That will give more room to see what's happening and also for movement. They can be put back on easily if not required to be removed.
For the main window it will be clipped or held in to the winder/motor somehow, and will have a guide rail.
I'm sure there's a how-to or other similar post on how to do this.
kjf7
  • lincolnshire
« Reply #2 on: 24 May 2009, 01:32:00 »
done windows are out cheers, why,s my writing so big
Welung666
« Reply #3 on: 24 May 2009, 07:33:28 »
It's not. Only big in the reply box :y
