Author Topic: ar35 from omega a to omega b  (Read 1941 times)
drefts
« on: 02 May 2009, 23:09:53 »
would a omega a 3.0 24 93.mod AR35 autobox fit in a omega b 2.5dt 95.mod with a ar25 box? i could get a box with conv and control box. anything more i need?
« Last Edit: 02 May 2009, 23:10:46 by drefts »
MutantCav
  • Gainsborough
Re: ar35 from omega a to omega b
« Reply #1 on: 02 May 2009, 23:12:08 »
Gearbox should be the same but you will need to use your current torque converter and bellhousing
drefts
« Reply #2 on: 02 May 2009, 23:39:40 »
ok. so i can't use the converter from it. thanks for real fast answer.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #3 on: 03 May 2009, 02:21:44 »
Just splitting hairs, but the Omega A is the Carlton. In Europe the Carlton was called the Omega.
All the Omega's as we know them are Omega B's ('94>'03).  :y
Omegatoy
  • UK
« Reply #4 on: 03 May 2009, 07:54:46 »
Nope!!! although it will physically fit, the managemnent systems are not compatible, where the omega a dipstick is on the b it is full of electronic connectors, it would just go into limp and nothing you could do would change it!! sorry dude,mind you the omega must have done a few miles  anyway, td wold kill it im sure!!
    • 530D M Sport, 330i Coupe
« Reply #5 on: 03 May 2009, 12:36:51 »
As above! Plus all the connectors are different anyway.
drefts
« Reply #6 on: 04 May 2009, 22:28:21 »
sorry, i know it is called Carlton but didn't think when i wrote.  ;D.
so in other words, there is no hope to mount a auto box from a Carlton in omega b... :'(
then i still have to look, was much easier too find one from Carlton  ;)
stevie1976
  • glasgow
« Reply #7 on: 04 May 2009, 22:34:15 »
as above connections will not fit :y
drefts
« Reply #8 on: 24 May 2009, 13:00:53 »
Ok. know i have a omega ar35 from a mv6 3.0. 98.mod will this fit right in to my omega 2.5td 95? and what do i need to takeover?
« Reply #9 on: 24 May 2009, 13:29:07 »
bellhousing and torque converter from the td
drefts
« Reply #10 on: 24 May 2009, 14:05:45 »
how about ecu for autobox and gearchanger
MutantCav
  • Gainsborough
« Reply #11 on: 24 May 2009, 14:07:18 »
Sorry for some reason I was thinking very early Omega (94/96) for Omega A...Carltons different...
94 Omega onwards Auto box will be usable though :y
Omegatoy
  • UK
« Reply #12 on: 24 May 2009, 18:13:45 »
nope td ecu will drive it just fine!! :y
