Author Topic: Power steering problem  (Read 1522 times)
ScottieMV6
  • Swinton, Manchester
« on: 21 May 2009, 09:32:53 »
Being the idiot that i am I forgot that I had drained the PAS reservoir while doing my thermostat and went to move the car yesterday.
I realised as soon as I tried to turn the wheels and stopped. I filled up with fresh Dexron 2 and started the car again but now the steering makes a nasty noise when I try to turn the wheels. Left the car running for 10 minutes to see if it just needed to get the new fluid moving but still the same.
What am I likely to have damaged? Just the pump or something else?  :-[
I'd rather be scared to death than bored to death!!
omega rick
  • witham essex
Re: Power steering problem
« Reply #1 on: 21 May 2009, 09:39:43 »
its prob just airlocked, you need to run the engine and put the steering on full lock both ways this should clear it
ScottieMV6
« Reply #2 on: 22 May 2009, 13:38:29 »
Tried it on full lock both ways a couple of times but no joy.
Assume its the pump? Is there anything else it can be?
The steering feels very "notchy" too now BTW.  :-/
« Reply #3 on: 22 May 2009, 20:01:21 »
It does sound like you've knackered your pump mate!  :'(
ScottieMV6
« Reply #4 on: 23 May 2009, 10:29:32 »
I seem to remember you saying you had done this job on yours Andy? How easy is it?
« Reply #5 on: 23 May 2009, 10:41:22 »
Not at all difficult, once all the bagpipes at the front are out the the way, access isn't too bad.
ScottieMV6
« Reply #6 on: 23 May 2009, 11:13:17 »
Thanks Andy. I think that might be a job for today. Well taking the old one off at least! :y
« Reply #7 on: 23 May 2009, 11:27:53 »
There were a couple of Omegas at the Pimhole the other week, and 3 at the far yard on Waterloo St Bolton.
« Reply #8 on: 25 May 2009, 13:12:09 »
Just had a look around Campbells at Bolton http://www.thomsonlocal.com/Campbell's-Dismantlers/0304686801101345000/map/companyinfo.html
he has 2 prefacelift cars & a facelift  4 pot (not recognising it I assume it's a 2.2 diseasal)
1 face lift only has 219000 miles on the clock ....  :-? and the other is a miniface lift 2.5 - might be a suitable power steering pump.  :y
« Last Edit: 25 May 2009, 13:21:15 by Andy_B »
