Author Topic: anti freeze  (Read 5061 times)
bfb1150gs
  • liverpool
anti freeze
« on: 25 May 2009, 19:50:33 »
does the pink vx longlife antifreeze need to be mixed with water
Re: anti freeze
« Reply #1 on: 25 May 2009, 19:52:15 »
in a word ........ yes! 50:50 ratio
bfb1150gs
  • liverpool
Re: anti freeze
« Reply #2 on: 25 May 2009, 19:54:02 »
the barstewards the parts bloke told me it dont need mixing so i just poured it all in , will this affect the cooling
Re: anti freeze
« Reply #3 on: 25 May 2009, 19:55:10 »
How much did you put in mate?
Re: anti freeze
« Reply #4 on: 25 May 2009, 19:55:45 »
hang on!
He could have given you pre-mixed.
Did he give you pure anti-freeze or ready mixed? Was it like water, or a bit thicker?
bfb1150gs
  • liverpool
Re: anti freeze
« Reply #5 on: 25 May 2009, 19:56:12 »
thicker
Re: anti freeze
« Reply #6 on: 25 May 2009, 19:58:41 »
How much?
Re: anti freeze
« Reply #7 on: 25 May 2009, 19:59:13 »
then next time you see the parts bloke, punch him, dumbass idiot.
Drain it out... flush with water. Get another bottle, mix it 50/50 with water, re-fill.
Guide in maint seciton
bfb1150gs
  • liverpool
Re: anti freeze
« Reply #8 on: 25 May 2009, 20:01:17 »
i did the cambelt last month and changed the water pump so i put 4-5 liters in
Re: anti freeze
« Reply #9 on: 25 May 2009, 20:02:10 »
So ..... you have 100% pink/red antifreeze in your car?
Drain a gallon/5 litres off and then re-fill with fresh water. that'll give you an aprox  50:50 mix!  :y
« Last Edit: 25 May 2009, 20:02:40 by Andy_B »
Re: anti freeze
« Reply #10 on: 25 May 2009, 20:02:31 »
Before you do that - how much did you put in??????????  Trying to help, plse respond
Re: anti freeze
« Reply #11 on: 25 May 2009, 20:03:55 »
Whole system is 9.7 Lits so if you only put 5 Lits antifreeze in and rest water then you're OK - 50:50 mix.
bfb1150gs
  • liverpool
Re: anti freeze
« Reply #12 on: 25 May 2009, 20:04:37 »
will this mix affect the cooling cos it seemed to heat up v-quickly going over the mountain road to applecross
bfb1150gs
  • liverpool
Re: anti freeze
« Reply #13 on: 25 May 2009, 20:06:38 »
i put in 1 -   5 litre  bottle
Re: anti freeze
« Reply #14 on: 25 May 2009, 20:07:20 »
Assumed you have a V6 - and not a 4 pot!  Would help if you put car details in your details :-/
Normal running around 95șC with fans cutting in around 97șC.
