Author Topic: Front Pads & Discs 98 V6  (Read 1834 times)
JezInBrum
  • Birmingham
  • Built for comfort not speed
« on: 25 May 2009, 15:14:48 »
Hi, Hopefully a quick one. I shall be replacing the Front pads & discs on my car over the next few days. I looked in the maintenance section & there is'nt a "how to". Only thing I am unsure about is, do I have to remove the caliper carrier on order to remove the disc. This seems to be an omission from the Haynes manual as well. One other thing. If I do need to remove it is it advisable to heat the struts around the mounting bolts prior to removal.
Thank you, Jez
Re: Front Pads & Discs 98 V6
« Reply #1 on: 25 May 2009, 15:19:09 »
JezInBrum
  • Birmingham
« Reply #2 on: 25 May 2009, 15:28:44 »
Thanks  :y
« Reply #3 on: 25 May 2009, 18:26:01 »
Beware, it need 18mm socket, not all older socket sets have 18mm
Markjay
  • London
« Reply #4 on: 25 May 2009, 21:09:10 »
Indeed... :(
When I did it... I had to leave my car parked in the street all jacked-up with the bits on the pavement, and bus it to the nearest motor factors to get an 18mm socket! Luckily they were open on the Saturday :)
Alas, no more Omegas....
« Reply #5 on: 26 May 2009, 11:56:07 »
Indeed... :(
Why is that? even hardened socket sets often miss 18 out. All the more annoying as some other marques wheel nut sizes use 18....?
JezInBrum
  • Birmingham
« Reply #6 on: 26 May 2009, 12:12:10 »
No fear, I bought two of them when i did the wichbones on my last Vectra. Thanks again
Markjay
  • London
« Reply #7 on: 26 May 2009, 16:54:43 »
Indeed... :(
And 14mm is another rarity....   :(
