Author Topic: Can I reuse head gasket & bolts?  (Read 4038 times)
Re: Can I reuse head gasket & bolts?
« Reply #15 on: 25 May 2009, 20:07:37 »
However I cannot remove 135 without doing 246 as well
Why's that?  :-/
Can't remove 135 without moving the coolant pipe, can't unbolt that with 246 in the way.
I have short fingers and wide hands.
Just asking ..... ;) as said else where I've never ever got that far on my car ....... yet!  :-?   ::)  ::)  ::) :-X
espen22
  • Norway(the coldest part of it)
« Reply #16 on: 25 May 2009, 20:34:36 »
rub the damage carefully with p800 wet paper, and remove all alu deposits from camshaft. think you will do just fine with that. check that there is no alu deposits in the hole where the oil is supposed to come up and lube.. think that the engine will be ok.
Martin_1962
« Reply #17 on: 26 May 2009, 08:47:22 »
Will have to reuse - dealer gone belly up :(
« Reply #18 on: 26 May 2009, 08:51:17 »
can you risk the bolts shearing on you?
stretch bolts being used twice here doesnt sound good to me,
Mark has had head bolts sheer, and with the force you are tightening can really do you some damage when the go and you punch some metal obect really hard :(
can you really not wait a day or 2 to be safe?
Martin_1962
« Reply #19 on: 26 May 2009, 11:28:02 »
Gasket looked OK
Short cut for changing - looses Coolant pipe the jack up the pre cat, saves unbolting the exhaust.
Currently looking for torque equivalences
Martin_1962
« Reply #20 on: 26 May 2009, 12:27:50 »
Didn't look too bad, I have torqued to 75nm - the limit for 10.9 rated M10 bolts.
Spares are being ordered ready for any issues.
« Reply #21 on: 26 May 2009, 12:45:22 »
What? The head bolts? :o (mental picture of head bouncing up and down on the block as the engine fires)
I would say it's fine to re-use the bolts. They have only had a single stretch cycle and not been subjected to numerous thermal cycles as they would in an engine in real "use".
If the head gasket is the metal type they would probably be OK to re-use at a push. Ideally replace them, of course.
Martin_1962
« Reply #22 on: 26 May 2009, 15:51:55 »
I did some measuring
20 nm + 215 deg
75 was about 120 deg and I gave it another 90
Too worried about breaking them
Spent a lot of the day chasing another down - no luck yet
Martin_1962
« Reply #23 on: 26 May 2009, 18:02:34 »
Seems OK
beemerdevil
« Reply #24 on: 26 May 2009, 18:29:51 »
I would get new ones matey :y
Martin_1962
« Reply #25 on: 26 May 2009, 18:49:49 »
New gasket & bolts ordered, will fit in a couple of weeks when all the cuts have gone.
That said now second quickest 2.6 on OOF
