Author Topic: Cam cover sealant  (Read 1376 times)
Martin_1962
Cam cover sealant
« on: 27 May 2009, 16:19:40 »
What exactly is it?
Any suitable on line sources for purchase?
I find it is a good sealer for other jobs so want some spare for non car use.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Cam cover sealant
« Reply #1 on: 27 May 2009, 16:20:36 »
why not get it from the stealers, not that expensive.
« Reply #2 on: 27 May 2009, 16:35:24 »
It's Loctite 598 or similar. Available from Halfrauds, etc. although the last tube of sealent I bought there (it will be the last too) was set solid in its' tube.
Dealer prices are probably pretty competitive - if they're still in business, of course!
Martin_1962
« Reply #3 on: 27 May 2009, 19:38:23 »
Just wanted a similar black sealer which was cheap.
  • Online Online
    • 530D M Sport, 330i Coupe
« Reply #4 on: 27 May 2009, 19:43:57 »
Loctite (910 IIRC) was used at the factory.
Bent valve
« Reply #5 on: 27 May 2009, 20:34:20 »
Its black silicone sealer. http://www.absealants.co.uk/
 although you will find that Soudal 40 FC  polyurethane from the same place is a much better general sealant.
« Last Edit: 27 May 2009, 20:41:18 by Bent_Valve »
