Author Topic: air con "coldness"  (Read 1358 times)
omegav6est
  • corsham wiltshire
air con "coldness"
« on: 28 May 2009, 00:52:50 »
hi all the air con on my mig works as it should except i am doubting the coldness on its lowest setting.it does get cold but not icy cold as i am told it should be.according to the service history the car had a new air con compressor and a regas at vauxhall last year but this was before i had it so i dont know how cold it was then.i know i can get it checked out at  a specialist but i was just wandering do these systems get very cold or is mine normal.thanks
Re: air con "coldness"
« Reply #1 on: 28 May 2009, 01:05:43 »
Mines icy cold - not been regassed in the 2+ years I've had it!
p j morgan
  • nottingham
« Reply #2 on: 28 May 2009, 01:20:15 »
they should be icy cold ,you probly need your gas topping up .you no what vx are like ,can't be trusted to do a proper job!  :y
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #3 on: 28 May 2009, 04:27:56 »
Check the valves first. They could be leaking very slowly.
