Author Topic: SOS Faulty Faulty  (Read 1553 times)
DaviesEB
  • Monrovia Liberia
SOS Faulty Faulty
« on: 29 May 2009, 12:27:55 »
Car could not start last night. EML blinks when you switch on before cranking.
Did a Paperclip this morning. 13, 14, 17
Any help for the Widow's Son Please.........
2.5 V6 Petrol
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
Re: SOS Faulty Faulty
« Reply #1 on: 29 May 2009, 12:32:14 »
2.5 V6 Petrol
Usually means a transponder problem .. check your key, undo the top/bottom halves and make sure the tiny little black chip hasn't moved !!!  If you have a spare key try that one.
DaviesEB
  • Monrovia Liberia
« Reply #2 on: 29 May 2009, 12:49:25 »
Thanks much. But unfortunately my key lost its chips long ago . so it is only the key alone that i have.
It seems to me that a 19 came up long ago. That was some two weeks ago. But i ignored it.
Cheers
DaviesEB
  • Monrovia Liberia
« Reply #3 on: 29 May 2009, 13:03:58 »
What is the cause of a flashing EML light when key is turned to ign II.
Thanks :( :( :(
MutantCav
  • Gainsborough
« Reply #4 on: 29 May 2009, 13:25:54 »
Flashing EML means the transponder signal is not being received and so the immobiliser normally would not let the car start as a result...key wont start the car without the immobiliser chip in it...
« Last Edit: 29 May 2009, 13:26:37 by ShieldOfSteel »
« Reply #5 on: 29 May 2009, 14:03:35 »
Thanks :( :( :(
The engine ecu hasn't received permission to start from the immobiliser ecu
DaviesEB
  • Monrovia Liberia
« Reply #6 on: 29 May 2009, 15:41:49 »
Is it because of 19. I do remember that the last paperclip gave me a 19.
Well do not have a crank sensor available but will purcahse one.
« Reply #7 on: 29 May 2009, 15:55:14 »
unlikely.
Is your car 1996 or newer? If so, its a transponder problem most likely
DaviesEB
  • Monrovia Liberia
« Reply #8 on: 29 May 2009, 18:29:17 »
Well do not know what to do with transponder. The mechanic tells me my fuel pump is faulty. Can this be. He tells me it is not pumping enough gas.
Please advice.
DaviesEB
  • Monrovia Liberia
« Reply #9 on: 29 May 2009, 18:43:45 »
Mine is a 98 Model Omega B 2.5  V6 Estate Petrol Engine.
Cheers
M8S
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« Reply #10 on: 30 May 2009, 15:59:35 »
if you got 19 then change the c/s, but listen to the others and check out the transponder
i am willing to trade my electrical labour for parts work etc
