Author Topic: Battery Drain  (Read 5315 times)
Tommy
  • Truro, Cornwall
Battery Drain
« on: 23 May 2009, 06:24:42 »
I have just discovered a problem with my 99 Elite as I'm now not using it daily.
It seems to be draining the battery after 2/3 days. I had bought a new battery on a Thursday and it was flat by Saturday - although it had done a few miles on the Friday. Took the battery back and it did have a bad cell. That was replaced on Wednesday of this week. Flat this morning (Saturday)
Alternator seems to charge fine once it's going
Any ideas please? I did read here about disconnecting the power sounder to the alarm
Bent valve
Re: Battery Drain
« Reply #1 on: 23 May 2009, 07:53:04 »
Check that your sunvisor lights go out
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #2 on: 23 May 2009, 09:14:30 »
Yes I've checked all the interior lights
Following on from http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
I have checked the amps between the battery + disconnected negative terminal I have a range (10amp) of 1.25 & 0.45 but it's not steady - continually changes
Just disconnected the powersounder and no difference
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Battery Drain
« Reply #3 on: 23 May 2009, 09:28:20 »
Have a feel of each of the relays, see if any are 'warm', not an exact science, but it may give you a clue.
I like red cars
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #4 on: 24 May 2009, 09:17:41 »
Are there any 'usual suspect' relays?
Re: Battery Drain
« Reply #5 on: 25 May 2009, 10:29:46 »
Ideally you need to leave it with the dorrs closed for about 10 minutes for everything to settle. Maybe tape down the driver's side door pillar switch, let it settle, then check for any warm relays, as said. Then move on to the fuse box in the driver's footwell and pull fuses one at a time to see if one drops the current.
Do you have an original radio or an aftermarket one?
Richgm
  • Tamworth
Re: Battery Drain
« Reply #6 on: 25 May 2009, 13:01:52 »
I've seen battery drain on 2 different makes of car recently. Both times it turned out to be the alternator draining the battery when the ignition was off. (It still charged OK when the engine was running).
Noli nothis permittere te terere
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #7 on: 25 May 2009, 14:11:32 »
Kevin,
Original radio (CCRT700) fitted
Will try your suggestion when it stops raining  :-[
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #8 on: 25 May 2009, 15:01:39 »
Just refitted the battery (after recharging) Gave each relay a little wiggle and tested and it was still ranging from 0.9 to 1.54. Left it connected for 20 minutes and no warm relays.
When I disconnected negative to retest amps I heard what sounded like a small motor whirr somewhere near the pollen filter area/wing mirror and the amps were steady at 0.93.
Same motor whirred when I reconnected the negative terminal
Richgm
  • Tamworth
Re: Battery Drain
« Reply #9 on: 25 May 2009, 18:49:36 »
Leave the ameter connected and pull the fuses one at a time until you see the current drop. Should help narrow down your search.
largecol
  • Middlesbrough
  • I cant see my socks!!
Re: Battery Drain
« Reply #10 on: 25 May 2009, 20:02:38 »
Sounds a bit obvious, but have you checked the boot lght aint permanently on? Cos that little so and so caused me no end of battery trouble.  :y
Pssssst! The man in my avatar aint really me!!
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #11 on: 25 May 2009, 22:10:21 »
I've never had a boot light come on
Tommy
  • Truro, Cornwall
Re: Battery Drain
« Reply #12 on: 29 May 2009, 11:51:34 »
Quick update
I haven't done the fuses yet but after 2 days of sitting with the alarm on she started first time. Drove around for 3/4 hour. No aircon on, no lights, no radio switched on.
Following morning I went out as she was being collected by lowloader (bonnet paint repair after a fire engine opened it's door on to my bonnet!!!) and the battery was almost flat.
I get her back on Monday but still puzzled
Richgm
  • Tamworth
Re: Battery Drain
« Reply #13 on: 29 May 2009, 11:56:21 »
Just out of interest what voltage do you have on the battery when the engines running?
Was thinking that maybe the altenator is putting some charge back into the battery but not enough.
nick v6
  • walsall / west midlands
Re: Battery Drain
« Reply #14 on: 29 May 2009, 12:01:21 »
my battery was doing the same mate
i put my daughter in the boot to see if the boot light went out which it was not
replaced the switch and all fine now :y
