Author Topic: Quick question on EGR  (Read 1107 times)
lou
  • Romford
  • Always expect the unexpected
« on: 30 May 2009, 15:04:23 »
When I remove EGR will I need a new gasket or can I reuse the old one and do I just fill the biggest hole with some cleaning agent or both holes?
Varche
  • middle of Andalucia
    • Golf Estate
Re: Quick question on EGR
« Reply #1 on: 30 May 2009, 15:38:30 »
I had problems with my EGr on and off and bit the bullet and removed it. I then made a blanking plate out of a fairly thick sheet of metal and refitted the EGr and used some blue gasket goo left over from over 30 years ago. Still going strong. I tried cleaning the inside of the EGR but gave up as I was blanking it off.
varche
Shagma
  • Norway
« Reply #2 on: 30 May 2009, 23:44:58 »
varche
What was the symptoms of faulty EGR...?
lou
  • Romford
« Reply #3 on: 30 May 2009, 23:47:16 »
No symptons at the moment, just perhaps for some routine maintenance or if it aint broke should I not fix it?
Shagma
  • Norway
« Reply #4 on: 30 May 2009, 23:56:29 »
im not qualified to answer these questions, but by default I would say that its worth a shot to reuse the old shim gasket, based on the fact that the torque on the bolts are limited.. As long as it looks fine visually of course..:)
Page created in 0.023 seconds with 16 queries.
