Author Topic: More fault codes ??  (Read 869 times)
Tonybazza
  • Lapford Devon
More fault codes ??
« on: 31 May 2009, 14:27:03 »
Hi again !!
My car is still running a bit lumpy after startup ,And i am finding it hard to start the car when the car is hot after running it for afew miles i have done the paper clip test again before the car gets hot i have no codes anymore but when the car has warmed up i get these codes below ??? please can you give me some advice .
thanks Tony
33   Exhaust Gas Recirculation (EGR) Valve Voltage Low
129   Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low
« Last Edit: 31 May 2009, 14:28:24 by Tonybazza »
Re: More fault codes ??
« Reply #1 on: 31 May 2009, 21:44:35 »
Sounds like egr needs cleaning/replacing.  You could try blanking it off to see if that cures the starting
Tonybazza
  • Lapford Devon
« Reply #2 on: 31 May 2009, 22:00:32 »
Thanks for the reply is there a how to ! blank of the EGR ? on the forum for the 2.5 i have looked but cant find one if someone could kindly point me in the right direction.
« Reply #3 on: 01 June 2009, 09:02:42 »
probably not. Just cut up a coke can, and pop it under egr.
