Author Topic: performance/poor fuel figs  (Read 1944 times)
Rottyman
« on: 01 June 2009, 21:09:32 »
Help,thought my miggy tractor was the dogs wen bought it.Room 4 my rotty,40mpg(20 wiv caravan)quiet 4 a deezl and cumfy.But now fuel figs dropped power really dropped(until turbo wakes up)then OMG its away like a gud un.Wud appreciate ne suggestions as 2 wot cause cud b,ta very muchly
Re: performance/poor fuel figs
« Reply #1 on: 01 June 2009, 21:13:38 »
Can someone translate, as I don't speak gibberish?
« Reply #2 on: 01 June 2009, 21:14:21 »
Can't help with the car problem ... :( as I know nothing about diesels but  ......
May I kindly point you to the forum rules which state
"Use English, no text speak which is notoriously difficult to read."
http://www.omegaowners.com/forum/YaBB.pl?virboard=general;num=1209458172
It took me 5 minutes to work out what you were asking ... :(
Edit ... must type faster .. :(
« Last Edit: 01 June 2009, 21:15:01 by entwood »
Rottyman
« Reply #3 on: 01 June 2009, 21:32:01 »
OK guys,sorry,in english,no acceleration to speak of until turbo kicks in,and poor fuel figures,any advice received with thanks(2.5 td)
« Reply #4 on: 01 June 2009, 21:33:19 »
try a 'paperclip test', works on some TDs...
Rottyman
« Reply #5 on: 01 June 2009, 21:39:45 »
Cheers boy,but please explain how 2 carry out test and will give it a try
« Reply #6 on: 01 June 2009, 21:42:59 »
Have a read here .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #7 on: 01 June 2009, 21:48:40 »
Possibly you've just got used to the oomph and the fuel economy has dropped because you're nailing it more.
If no codes showing after P/Clip test, then it's time to chip it :y
Rottyman
« Reply #8 on: 01 June 2009, 21:54:26 »
I wish that was true Turk,but believe me its all oomphed out until turbo joins the party
Rottyman
« Reply #9 on: 01 June 2009, 21:56:27 »
Cheers boy,will give it a whirl at weekend,fingers crossed it'll be summat easy 2 fix
Omegatoy
  • UK
« Reply #10 on: 01 June 2009, 22:00:10 »
Hmm if it suddenly takes off around 2k rpm thats fairly normal, however later than that you have a problem!!
always best to start with the basics such as full servce with air and fuel filters oil etc, does itstart well or take a lot of turning on the starter?
Rottyman
« Reply #11 on: 01 June 2009, 22:11:16 »
I have heard of warm start probs,but got none of that,its as i bought it less the initial go go and economy
Page created in 0.037 seconds with 17 queries.
