Author Topic: Centre bore shims  (Read 911 times)
Bumbazor
  • Worksop
Centre bore shims
« on: 02 June 2009, 10:22:20 »
I have some wheels to fit to my car but being an aftermarket type I require shims so they fit properly.
I have had a look online but I can't see anywhere to get them from.
Can they be custom made, and if so where is a good place that does them?
Also am I right in saying the bore on the car now is 65.1?
markey mark
  • SLady bitshorpe north lincs
Re: Centre bore shims
« Reply #1 on: 02 June 2009, 11:54:04 »
most alloy wheel dealers will be able to get them spigot rings they are called  :y
