Author Topic: Front brake pads  (Read 971 times)
lou
  • Romford
  • Always expect the unexpected
Front brake pads
« on: 02 June 2009, 17:58:41 »
Perhaps this has been asked before but how do the pads fit into the caliper as one pad has a shim (metal plate on the back) but the other one has not. At the moment the one with the shim is on the piston side..opinions would be appreciated.
JezInBrum
  • Birmingham
  • Built for comfort not speed
Re: Front brake pads
« Reply #1 on: 02 June 2009, 18:31:35 »
As far as i know thta is the correct way round. Set i just fitted had them on all four. When replacing use copper slip as well as this helps reduce the chance of squealing brakes
« Last Edit: 02 June 2009, 18:32:23 by JezInBrum »
« Reply #2 on: 02 June 2009, 18:33:03 »
[size=18]ChrisGixer!!!!![/size]  ;D  ;D :y  :y  :y
« Last Edit: 02 June 2009, 21:55:28 by Andy_B »
