Author Topic: My reversing sensors are not beeping  (Read 1384 times)
Martin_1962
« on: 02 June 2009, 19:05:34 »
After market kit an found out tonight they don't work - will have to trace all the wiring tomorrow and try to fix. :(
    • 530D M Sport, 330i Coupe
Re: My reversing sensors are not beeping
« Reply #1 on: 02 June 2009, 20:00:21 »
Presuming you have wired it into the reverse light 12V so are the reversing lights coming on?
Martin_1962
« Reply #2 on: 02 June 2009, 20:10:18 »
Just rewired the buzzer (fractured wire) and very very quiet.
Will check voltage tomorrow and obtain a new buzzer :(
Martin_1962
« Reply #3 on: 02 June 2009, 20:10:48 »
They have been on over 3 years :-?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 02 June 2009, 20:19:43 »
Are you going backwards? :question
Bent valve
« Reply #5 on: 02 June 2009, 20:30:23 »
How did you find out?
« Reply #6 on: 02 June 2009, 20:33:13 »
Hopefully by giving a good bump to a BMW, as I did the other day in a very tight space that I squeezed into :D :D :D.  No damage to either car, but the other woman driver wasn't happy ::) ::) ::) ::)
« Last Edit: 02 June 2009, 20:33:34 by Lizzie_Zoom »
  • Online Online
« Reply #7 on: 02 June 2009, 20:33:41 »
Suddenly?  ;D  ;D  ;D
Martin_1962
« Reply #8 on: 02 June 2009, 21:51:36 »
Didn't go beep beep beep when I put it into reverse
Will check Maplins later in the week
Martin_1962
« Reply #9 on: 02 June 2009, 21:52:24 »
I rebuilt the buzzer, new wires (old were damaged) but the buzzer plate is now too quiet
kjf7
  • lincolnshire
« Reply #10 on: 02 June 2009, 23:43:12 »
maybe you have'nt got close enough to anything to set it off ;D ;D
