Author Topic: Help - any photos of LPG engine bay layout V6 pls.  (Read 1521 times)
odthing
« on: 02 June 2009, 09:05:11 »
Does anyone have photos of how they laid out their engine bay for LPG conversion stuff in a V6 Omega, and photos of injector drilling please?
Re: Help - any photos of LPG engine bay layout V6 pls.
« Reply #1 on: 02 June 2009, 11:37:50 »
There are some photos of my installation Here: http://www.omegaowners.com/forum/YaBB.pl?num=1216678718
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 02 June 2009, 11:38:01 »
Have a good search on here, as someone has done all the above before with a step by step guide too :y
Dazzler
« Reply #3 on: 02 June 2009, 11:38:30 »
To late ::) ;D
odthing
« Reply #4 on: 02 June 2009, 14:56:22 »
Thanks, that's very helpful. What drill size did you use for the injectors? Mine is a 2.6l V6, Regards, Will
wingman
  • Hastings
    • Grandland GS
« Reply #5 on: 02 June 2009, 20:18:50 »
If you PM me with your E mail address I will send you some photos of my installation. In this case the injectors were not fitted in the manifold. Instead the injector blocks were mounted on top of the plenum with pipes from them leading to 6 nipples drilled and tapped into the top of the plenum. On the inside of the plenum, long plastic straws then go into the manifold trumpet and reach down onto the top of the valves. Doing this way makes it much easier to change the plugs IMHO and seems to work just fine in my case (3.2 DBW with long plenum)
« Reply #6 on: 03 June 2009, 10:50:15 »
Do you mean drilling out the nozzles in the injectors or for the tapped holes?
The injector nozzles were drilled out to 3.0mm. For a 2.6 I would suggest starting a bit smaller, prehaps about 2.7mm.
The nozzles are M6 thread, so a 5mm diameter hole in the manifold before tapping IIRC.
« Reply #7 on: 03 June 2009, 10:55:21 »
Some pictures of mine here, although Kevin's will probably be more help to you as he has a Facelift :y :y :y
http://
http://www.omegaowners.com/forum/YaBB.pl?num=1219174789
