Author Topic: Good News, Bad News, Help Please  (Read 2251 times)
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« on: 26 November 2007, 17:53:22 »
Good News:
Had the day off to try to rectify the wife's Astra idleing problem, it was very up and down and seemed like it wanted to stall so it kept revving up and then falling away, if you see what I mean. Went to the Vx dealer for a new throttle body gasket and to the local motor factors for a new air filter. As I was working on the car I wore a boiler suit and didn't change to go for the bits, both of them gave me trade discount without even asking. The moral of the story I guess is to look the part and they don't question you.
Bad news:
The throttle body was a lot more complicated to do than the Omega, lots of pipes and sensors and a throttle cable thingy, what's that for?  ;)
Anyway, I lost my bottle at the last minute and didn't take the whole thing out although I had disconnected practically everything and I did give it a wipe around with a rag and changed the gasket and air filter. Reconnected everything and tightened and torqued everthing properly.
The car still idles at around 1,000 rpm, although this is quite steady, but this seems too high to me. This is even after a 30 minute run back from St Austell around the lanes so the engine was definately up to temperature.
Help:
My questions are, what else could cause the car to idle so fast? Does the throttle look so dirty that this could be the culprit? Is 1,000 rpm too high an idle speed?
The car is a 1998 Astra G, 1.6l 16v.
« Last Edit: 26 November 2007, 17:54:18 by martin_saint »
[size=24]        [/size][/b]
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Good News, Bad News, Help Please
« Reply #1 on: 26 November 2007, 17:56:48 »
Good News:
Bad news:
Help:
My questions are, 1.what else could cause the car to idle so fast? 2,Does the throttle look so dirty that this could be the culprit? 3,Is 1,000 rpm too high an idle speed?
1, Dont Know.
2, Who Cares.
3, Maybe
I hope this helps :y :y :y
« Last Edit: 26 November 2007, 17:57:59 by Crazydad »
MikeDundee
  • Costa Del Peckham
« Reply #2 on: 26 November 2007, 17:58:34 »
Good News:
Bad news:
Help:
Mine idles at around 500 when it does'nt stick at 1500 ::)
« Last Edit: 26 November 2007, 17:58:53 by mickdundee »
Golfbuddy
  • Cornwall
« Reply #3 on: 26 November 2007, 17:59:15 »
Good News:
Bad news:
Help:
1, Dont Know.
2, Who Cares.
3, Maybe
Your input is greatly welcome as ever Steve.  :P
MikeDundee
  • Costa Del Peckham
« Reply #4 on: 26 November 2007, 18:12:33 »
Good News:
Bad news:
Help:
1, Dont Know.
2, Who Cares.
3, Maybe
I'll second that
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #5 on: 26 November 2007, 18:15:11 »
Thanks Guys :'( :'(
Its nice to know that i am a well respected member of the Forum. I try to do my best to help you along
the thin line. 8-) 8-) 8-) ;D
MikeDundee
  • Costa Del Peckham
« Reply #6 on: 26 November 2007, 18:21:27 »
Thanks Guys :'( :'(
No problem anytime :y, I might have posted the same comment but you done it first ;D ;D
raximax
  • dundee
« Reply #7 on: 26 November 2007, 18:33:56 »
choke stuck :-/  :question
« Last Edit: 26 November 2007, 18:34:23 by raximax »
mmeeggaa
STMO123
« Reply #8 on: 26 November 2007, 18:38:07 »
That throttle body needs to come off Martin, and then a damn good clean. It only takes a small amount of crap to stop them working properly. Are all your vacuum hoses seated right?
Taxi_Driver
« Reply #9 on: 26 November 2007, 19:21:51 »
Maybe be worth leaving it a few days, to see if ECU adjusts the idle speed...
My Omega idled fast for a few days after I changed an air filter that had done 60k.....after a few days it slowed back down again....think it just needed to learn it had more air coming in than it was used too.
Edit......i thought you had cleaned the throttle body in situ when i first read your post.......if its still that dirty as the photo......it needs a bloody good clean  :y
« Last Edit: 26 November 2007, 19:46:14 by Taxi_Driver »
« Reply #10 on: 26 November 2007, 19:36:46 »
As a suggestion with my weak knowledge this would be the order if I try
Cleaning throttle area
cleaning IAC valve
changing CTS (if this is gone also worth checking Thermostat)
I'm a little expensive mechanic isnt it ?  ;D
ps: also worth checking air leakage..
« Last Edit: 26 November 2007, 19:37:47 by cem_devecioglu »
Golfbuddy
  • Cornwall
« Reply #11 on: 26 November 2007, 22:04:33 »
I was afraid of that. What a bloody horrible job, so many pipes and sensors and tubes. And it's right at the back of the engine so your leaning over all the time.
Still, will give it a go this weekend then.
Thanks Steve. I knew there was someone sensible on here.  ;D ;D
Thanks to Dave and Cem also for your input. Looks like I will just have to do the full job then.  :y
STMO123
« Reply #12 on: 26 November 2007, 22:06:49 »
Now then ;D ;D ;D ;D
Dazzler
  • Haverhill, Suffolk
« Reply #13 on: 26 November 2007, 22:15:24 »
Remove and clean the black electrical bit to the left rear of your pic. Its the idle control valve, make sure you clean it and the hole in the throttle housing as these get very sooty and cause most of the idle problems on the astra ;)
Golfbuddy
  • Cornwall
« Reply #14 on: 26 November 2007, 22:18:44 »
Cheers Dazzler. Definately looks like I'm breaking the wife's car this weekend then.
Could be worse, it could be mine.  ;D
