Author Topic: help with starting problem after dirty derv  (Read 895 times)
bellers
« on: 04 June 2009, 00:18:17 »
got some cheap derv  ::)
well lets just say it has caused some bother. had starting problem and changed derv filter and it started fine tried to drive it all out and again ive now got starting problem agian. had bout 15L left and threw 20quid in it tonight. still has problem. starts from cold but when warmed up and no heater plug light on it wont start
i plan tomorrow to clean lift pump in the tank. if i take it apart like in the guide in here will i need to bleed after?
any other things that could be a problem
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: help with starting problem after dirty derv
« Reply #1 on: 04 June 2009, 09:28:05 »
It's generally accepted that if difficult starting occurs when the fuel level drops to around the 20 litre mark, that the problem is within the in-tank pump. You may be lucky and find a load of crud build-up in the swirl chamber or pump strainer.
You may need to bleed after doing this, though I didn't need to on mine.
When you've reassembled, turn the key to position 2, and you should hear the in-tank pump running for a short while. Then try to start, and see where you go from there.
Best to put a few gallons of fresh 'legit' diesel in the tank to kick things off too!
« Last Edit: 04 June 2009, 09:34:56 by Reliance505 »
Omegatoy
  • UK
« Reply #2 on: 04 June 2009, 09:31:39 »
oh oh!! dirty diesel will cause driveability problems would think the pot will be covered in crap for sure? after lift pump would treat it to a good quality diesel cleaner direct into filter,
diesel magic or forte diesel flush are good ones just fill filter with it then replace and run engine for ten mins or so, then see how it performs after that  :y
Seth
« Reply #3 on: 04 June 2009, 09:45:42 »
Absolutely - a good drink of Diesel Magic/Forte has benefitted many a tractor!
And don't use 'supermarket' diesel, spend a few coppers extra on 'proper' filling station stuff.
