Author Topic: Tapping noise. 2.2 16v  (Read 4348 times)
jampot1979
  • stevenage, hertfordshire
« on: 28 May 2009, 13:25:39 »
Hi, My omega has a slight tapping noise. It seems to get worse when the engine is warmer. Ive had an oil change and the manifold has been checked over with a new gasket. After the recent oil change it seems to be abit quieter.
Any ideas what I can do it solve this without spending loads? Engine runs smooth .
AndyMV6
  • Wiltshire
Re: Tapping noise. 2.2 16v
« Reply #1 on: 28 May 2009, 13:50:56 »
Hi,
does it come and go, or is it always present?
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 28 May 2009, 13:56:08 »
Did the car ever run out of oil maybe?
jampot1979
« Reply #3 on: 28 May 2009, 14:48:16 »
When I start the car up from cold the engine is quiet. Its when it get warm the tapping noise can be heard. The noise is always there until engine is cold again. Its had an oil change recently which made it quieter. levels are fine and never been run low.
« Reply #4 on: 28 May 2009, 16:42:47 »
what type of oil are you using?
GM 10/40 is very good value on trade, i would suggest 3 oil changes, 1 every 500 miles, then see what happens.
I did that for around 2k on my 2.2, made it much quieter!
jampot1979
« Reply #5 on: 28 May 2009, 18:00:46 »
Thanks for the replies. Just went out and lifted the bonnet to have a good listen. The tapping noise seems to sound like its coming from the top of engine. Its really hard to tell. Does the 2.2 ecotec 16v engine have hydralic tappets? Is there an additive i could use?
jampot1979
« Reply #6 on: 28 May 2009, 18:09:37 »
Oh, does my car have a cam belt or chain? could that be another possibility with the noise?
« Reply #7 on: 28 May 2009, 21:06:00 »
its belt.
when was the belt last changed? Did the tensioners get done too? It must be done every 4 years / 40k which ever comes first, without fail.
Its worth checking the timing.
« Reply #8 on: 28 May 2009, 21:09:30 »
Isn't it just tunnie - remember yours in Feb 07? ;D
« Reply #9 on: 28 May 2009, 21:18:25 »
yeah and it sounded like a bang of spanners before, sounds sweet as a nut now  :y
jimmas
  • stevenage, herts
« Reply #10 on: 28 May 2009, 21:39:11 »
yes it has a cam belt, also possibly sticking cam follower as they are hydraulic, regular oil changes may improve on it as already said.
jampot1979
« Reply #11 on: 29 May 2009, 07:52:48 »
Just drove to work today and all is quiet the first few miles, then the tapping noise reappears. The car drives fine etc.
Sometimes it sounds like its coming from the cat area but its hard to pin point. Could be completely wrong.
mathewst
  • Split, Croatia
    • v40
« Reply #12 on: 29 May 2009, 08:17:50 »
When was your cambelt changed?
Also one other thing, how much miles did the car do?
I had something similar happen to me once on fiat but this was the result of oil leak, and you said your oil is normal all the time :-/
jampot1979
« Reply #13 on: 29 May 2009, 12:42:36 »
Car has done 107,000 miles. Full vauxhall history. Cambelt done just over a year ago.
bluehawk
« Reply #14 on: 02 June 2009, 16:10:12 »
how much driving do you do a day is it short or long journneys , i had a similar sound and i only normally did short journeys most of the time 2 mies each way to work i gave it a good run and it has now disappered
