Author Topic: Some questions from a new owner  (Read 3914 times)
Re: Some questions from a new owner
« Reply #15 on: 03 June 2009, 22:43:43 »
Climate control - noisy fan - check fixing bolts tight - or could be fan bearings knackered.  Fan located up behind glove box.
omegadan67
  • northampton
« Reply #16 on: 03 June 2009, 22:55:23 »
On very early Omega's the aerial was built into the rear windscreen, sounds as if yours just needs tightening.
regards
richarda
All Omega saloons have the radio aerial built into the rear screen!
the radio aerial is on the roof its a 99 saloon its not in the rear heated screen or am i looking at something totally different
A little infomation is dangerous in the wrong hands
« Reply #17 on: 03 June 2009, 23:00:38 »
There's an aerial on your roof. But your radio aerial is in your rear screen with an amplifier under the parcel shelf.
NaughtyNigel
  • Sedgefield, Co Durham
  • Naughty Nigel
« Reply #18 on: 03 June 2009, 23:21:09 »
Here we go, couple of other things  ::)
The alarm siren does not sound when the alarm goes off, looking at another recent thread I should be looking at the powersounder? Does this sound right? Are the batteries easy to obtain?
Also, I am having difficulty deadlocking the car. It'll lock fine on the remote but the total closure is a bit hit and miss and it will only deadlock on rare occasions? Could this just be the remotes needing a fresh battery?
Thanks again  :y
That could be related to the alarm not working. You will probabaly need to take it to a main sdealer to get that sorted. I had to get mine replaced before they could program a new key for me.
NN
Why drive fast when you can drive fast in style? :)
NaughtyNigel
  • Naughty Nigel
« Reply #19 on: 03 June 2009, 23:24:05 »
The roof aerial was only ever fitted to cars with factory fitted phone kits. The radio aerial is the rear screen heater element.
nemo
  • Tonbridge Kent
« Reply #20 on: 04 June 2009, 18:33:20 »
check the wiring loom on the left hand side of the boot lid for breaks in the spoiler brake light feed where the hinge is or new light on e-bay about £30 delivered
