Author Topic: Broke down again  (Read 1135 times)
Martin_1962
Broke down again
« on: 04 June 2009, 10:04:17 »
3 miles on the way to work - heard a funny noise and immediately stopped.
Checked car - cam belt in one piece, water pump pulley had two loose bolts - retightened them.
Misfired all the way home, running on 135, 0300 0302 0304 - didn't bother waiting for 0306
Before a lift arrived, plug 2 wet, plenum not yet removed nor bagpipes, but will remove when home.
Why would a whole bank go down like that?
Martin_1962
Re: Broke down again
« Reply #1 on: 04 June 2009, 11:44:03 »
Water pump pully - need to find out if me or electric place left loose - I know it worked loose.
Could it have jammed the cam belt at all and caused tooth jumping?
What else could cause all the 246 misfire errors?
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 04 June 2009, 11:54:12 »
Yikes things ain't going well Martin.
Isn't the water pump driven by the Aux belt? Can't see how it would have affected the cambelt unless something had actually broken off the body of the pump.
« Reply #3 on: 04 June 2009, 13:29:06 »
The alternator lot should not ahve touched the water pump.
Is the coil pack plugged in?
Is the additional capacitor at the rear of the 2-4-6 bank also connected?
Does it run ok with the MAF disconnected?
Martin_1962
« Reply #4 on: 04 June 2009, 14:10:47 »
May be my fault, may be theirs - but it was fine on Monday
It was - now in boot
What does it do - yes I did reconnect it when I refitted the heads
Will check when I reassemble.
That said plug 2 was slightly wet
Martin_1962
« Reply #5 on: 04 June 2009, 19:15:11 »
It had been dismantled - found the front ram wire routed differently
water pump pulley OK, timing spot on, either coil pack or wiring to coil pack
0300 0302 0304 0306
« Reply #6 on: 04 June 2009, 22:11:24 »
water pump pulley, bolts aren't tight, but should be loctited iirc
