Author Topic: black headlights?  (Read 3125 times)
matty
  • Nr Peterborough
black headlights?
« on: 04 June 2009, 13:53:29 »
anyone taken a light apart and sprayed the inners black?
MikeDundee
  • Costa Del Peckham
Re: black headlights?
« Reply #1 on: 04 June 2009, 13:56:44 »
Not that I know of, but you can buy them off e-bay, or at least used to be able to, but not sure they're legal in the UK. There was a thread somewhere about it
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 04 June 2009, 14:02:35 »
From what I saw on ebay those black headlights were only for prefacelift models
i260
  • Newport, South Wales
« Reply #3 on: 04 June 2009, 15:11:31 »
Looks like turbomega's are blacked out!
Saab 9-5 Aero 260ps
miniator
  • Northern Ireland
    • My YouTube Channel
« Reply #4 on: 04 June 2009, 15:27:01 »
looks good that but id be afraid of having steamed up lights afterwards!
Omega Wanted: Facelift, 3.0/3.2, Elite/MV6, Charcoal Interior, W.H.Y.
« Reply #5 on: 04 June 2009, 16:12:43 »
....... id be afraid of having steamed up lights afterwards!
Why?  :-?
« Last Edit: 04 June 2009, 16:13:02 by Andy_B »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #6 on: 04 June 2009, 16:52:35 »
would the light not be crap then due to the lack of reflector? :-/
He who brakes Looses
To old to die young
« Reply #7 on: 04 June 2009, 16:58:55 »
The reflector hasn't been painted.  :y
miniator
  • Northern Ireland
« Reply #8 on: 04 June 2009, 17:24:01 »
Why?  :-?
in case you dont get a good seal again after splitting the lights. a pet hate of mine is steam/moisture in lights!
a few people on a local forum have done it, set the light into an oven at a low temperature to soften the glue and then prize (sp) the lense off...or a heat gun has also been used
markey mark
  • SLady bitshorpe north lincs
« Reply #9 on: 04 June 2009, 17:44:22 »
i have black lights in mine bought of ebay but came left hand drive only so converted mine to xenons  8-) 8-)
SJKOO01
« Reply #10 on: 04 June 2009, 18:36:23 »
I beliave it can be done DIY, but it's a bitch to do without breaking the light units.
There's the rubberry tacky black seal which isn't easy to separate the lens from back of the unit.
Did something simaliar with Astra Mk4 headlight - Worth it if you have the time and patiences of a saint !!.  ::)
miniator
  • Northern Ireland
« Reply #11 on: 05 June 2009, 11:22:29 »
read my above post....its simple to split the lights without breaking them
« Reply #12 on: 05 June 2009, 12:13:56 »
IIRC I used a Stanley knife to gently cut through the glue/sikaflex. They opened up quire easily.  :y
matty
  • Nr Peterborough
« Reply #13 on: 05 June 2009, 14:46:25 »
might buy a spare set and give it a go!
amba
  • Medway towns
    • German V6
« Reply #14 on: 05 June 2009, 15:25:59 »
Just spent about 1 hour pulling the lenses off a set I bought .They come off ok if you heat it up with a hair dryer and then start at a corner with 2 fairly blunt 1 inch chisels and a couple of stanley knife blades to keep cutting the black gunge.
Yes patience is required but fairly simple job....I now have the existing ones to remove from my xenons,as they are past it,then I will have nice clean new lights.
Does anyone know what the sealer is that is used ? as will run a bead around both when I refit them just to be sure of a decent seal again.
