Author Topic: cutting out  (Read 793 times)
GRAHAM123
cutting out
« on: 05 June 2009, 21:06:29 »
car intermittently cuts out under tickover, there is a fluc tuation in the revs it will drop from 500 down to 300 then pick up before eventualy cutting out. If you try and start car immediatly it fires up runs rough and then cuts out again. But if you leave for a minute or two it fires normaly and runs ok. I have changed idle control valve which hasnt cured it, my mechanic has mentioned air flow meter, and someone else fuel filter. Also my mechanic has mentioned servicing butterflies and throttle body housing. What else can we try? Also we have no engine management lights glowing or flashing.
Re: cutting out
« Reply #1 on: 06 June 2009, 01:19:01 »
try the link below
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
your profile does not give engine size so cant advise the method you need, but it is explained
see if you have any codes
