Author Topic: Cam shaft pin fell out  (Read 2042 times)
Martin_1962
« on: 06 June 2009, 09:57:56 »
HELP
The locating pin has fallen out - not snapped - how do I repair it?
KillerWatt
Re: Cam shaft pin fell out
« Reply #1 on: 06 June 2009, 10:20:02 »
Does this locating pin actually hold the camshaft sprocket in a certain position with respect to the camshaft itself?
If so, that "noise" you heard just before bank 2,4,6 died was probably the valves being bent as the camshaft itself stopped moving while the cam pulley was allowed to spin freely.
Sorry to be the bearer of potential bad tidings, but you may as well prepare yourself for the worst  :(
« Reply #2 on: 06 June 2009, 11:27:49 »
HELP
Looking at the pictures in the Haynes manual, how did the pin fall out? There's a bloody great big plate washer holding it in place via the bolt that holds the sprocket to the cam. :-/
Martin_1962
« Reply #3 on: 06 June 2009, 11:29:49 »
HELP
It slid into the sprocket keyway
« Reply #4 on: 06 June 2009, 11:31:38 »
 :( I've only Haynes pictures to go by, I've never done the job.
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 06 June 2009, 12:42:47 »
best get the head off martin valve damage will have happened bud sorry !! in all the miggy motors i have repaired or stripped never seen one of them move !! check the end of cam isnt cracked pretty sure there a very tight fit  :o :o
Martin_1962
« Reply #6 on: 06 June 2009, 12:48:24 »
Your heads are OK
The cam pin has been loctited in then gently hammered in.
I iwll reassemble after dinner
markey mark
« Reply #7 on: 06 June 2009, 12:51:19 »
did you check for a crack in camsaft bud ??? :(
Martin_1962
« Reply #8 on: 06 June 2009, 12:55:18 »
Looks fine
LK has no more anyway
I have to have some good luck sometimes
markey mark
« Reply #9 on: 06 June 2009, 12:56:03 »
Looks fine
 ;D ;D ;D yes mate you do
Martin_1962
« Reply #10 on: 06 June 2009, 12:57:56 »
I better rebuild my original heads for spares I think
They need porting though
I might need to drain some oil due to the rain
