Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16   Go Down
Author Topic: had just about enough now, a sad day for my car!  (Read 33660 times)
Wayne
Re: had just about enough now, a sad day for my car!
« Reply #105 on: 08 April 2009, 08:01:53 »
Grrrrrrrrrrrrrrrrrrrrrrrr!!!!!
funny though! i did LARF !!!  lol
« Reply #106 on: 08 April 2009, 08:04:01 »
As previously said, ignore the idiot in the village, he should stick to his BMW Minis (I know of him)[/quote]
im not gonna argue on here, the guy does ALL Makes of cars, he is a Genuine mechanic, unlike others i have come across, he doesnt rip you off and charges a good price for the work he does..
he NEVER has cars go back with problems he hasnt sorted after he has done them[/quote]
Yes, but hes clearly pretty shite as he cant make a basic accurate diag.
I for one will not be commenting on this thread any longer as you have been told a shite load of times its not head gasket yet headless chicken mode continues!
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #107 on: 08 April 2009, 11:45:29 »
I too am a musician & replaced my sucession of Volvo V70s with the Omega Estate because it has more load space & the PA just keeps getting bigger!
Arrive at a gig & people cannot beleive that all of that kit came out of 1 car. I use a VX steel dog-guard to prevent it from taking my head off under heavy braking BTW :)
Wayne
« Reply #108 on: 08 April 2009, 13:54:52 »
looks i have upset Mark, sorry mate!
im not running round like a headless chicken now! honest!
i bought some VX Red Coolant today and topped my car up this morning, it had dropped down about quarter of a pint, slightly more, no leaks anywhere..... maybe it was just settling itself from when i done the coolant change yesterday?
also topped up the oil with some 10W 40
put about 3 quarters of a litre in it
i also took some pics of the oil filler and cap, no sludge as you can see
http://www.facebook.com/photo.php?pid=6414349&l=8784f1c8d8&id=623190360
http://www.facebook.com/photo.php?pid=6414350&id=623190360
and i also took picture of the dipstick and the oil that's on it, i think this is Normal??  yes it is a bit black, lol
or is this the "gunk" you all mean?
http://www.facebook.com/photo.php?pid=6414351&id=623190360
http://www.facebook.com/photo.php?pid=6414353&l=969d144209&id=623190360
Welung666
« Reply #109 on: 08 April 2009, 13:57:36 »
Can't see the pics mate.
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #110 on: 08 April 2009, 14:00:22 »
I think you may well be going back to the stealers now wayne for you problems to be sorted, still this thread has helped your post count far more than it has helped you understand that people on here were trying to help you, good luck  ;D
Wayne
« Reply #111 on: 08 April 2009, 14:09:37 »
i wont be going back to the stealers mate, have no intention of doing anything to my car, just gonna drive it and top up the coolant until it goes bang
Welung666
« Reply #112 on: 08 April 2009, 14:12:19 »
Well I've offered to help twice now as I'm 90% certain I know what it is, but hey ho  :-?
omegadti
  • Glasgow
    • omega dti
« Reply #113 on: 08 April 2009, 15:40:17 »
I had my dti serviced at "stealers" at 40k, went back the next day to complain about low oil level and they told me I had a faulty engine that was not covered under warranty and would cost £2k to fix - I put a pint of oil in and it was fine!!!!
moral of the story - do not go to main dealers for anything!!!!!
« Reply #114 on: 08 April 2009, 16:17:58 »
Right.....well lets consider a headgasket setup ala this:
Which is a V6 head.
Blue - Water cooling jacket - will be at pressure
Brown - Oil return to block - kept at a slight avccum thanks to the engine breather system setup
Red - Oil feed - High pressure.
So, under a head gasket failure we can get a few scenarios.
A) Failed fire rings. This results in exhaust gases in the coolant and major pressurisation plus coolant being pulled into the bore on the inlet stroke.. When turned off, the cylinder pressure drops to atmospheric water (which remain at pressure for some time) will enter the bore. Classic symptoms are miss fires when starting.
B) Failure of the coolant jacket. This results in either a coolant leak external to the block (seen on some V6 engines) or water in the oil (very unusual on the V6 due to the small aand confined areas of the oil returns)
C) Failure of the gasket around the high pressure oil feed. This can result ina  ajor external oil leak (rare) or possibly oil in the water (also very rare). Thsi failure is  unheard of on the V6!
Your symptoms are coolant loss and a non working heater.
The latter we already know is due to a vaccum issue somewhere.
The coolant loss is the one that needs tracking down....it could be a number of things.
Wayne
« Reply #115 on: 08 April 2009, 16:59:54 »
Mark - thanks for that mate
im beginning to calm down and not panic after your above posting
i`m now ignoring the VX Basturds!
i just need to run my engine hot and see if i have any leaks, i dont have any ramps to jack it up high enough to see...
i topped up today with more red stuff, will drive her tonight for 10 miles and then look in the morning to see if its gone down again...
even if i have to climb underneath her withour ramps, then so be it
Welung 6666
i haven't forgot mate!
are you free this Friday or Saturday?
i would really appreciate your help !
we gonna do the solenoid vac thingy?
« Last Edit: 08 April 2009, 17:43:06 by Wayne »
VX1
  • Reading, Berkshire
« Reply #116 on: 08 April 2009, 20:02:38 »
Wayne................................
[size=24]DO NOT LISTEN TO OR TAKE YOU CAR TO THE DEALERS AS THEY TALK ALOAD OF SHITE. YOUR HEADGASKET IS NOT THE PROBLEM. YOU HAVE A SLIGHT WATER LEAK WHICH NEEDS SORTING. YOUR HEATING PROBLEM IS TO DO WITH YOUR VACUUM SET UP I.E  THE VACUUM PIPES ARE THE WRONG WAY ROUND. PLEASE PLEASE PLEASE LISTEN TO WHAT THE GUYS ON HERE STATE, THEY KNOW THE OMEGAS INSIDE OUT. YOU HAVE A PROBLEM THEY WILL HELP YOU TO SORT IT OUT. ALWAYS PUT YOUR PROBLEMS THAT YOU HAVE WITH YOUR MIG ON HERE FIRST.[/size]
Sorry to all the others members on here for shouting but I beleive this is the only way that Wayne will take note of what we all are saying.
Paul :y
Vx Trade club card holder
Halfords trade card holder
« Reply #117 on: 08 April 2009, 20:04:01 »
Paul :y
Fear not, we are now on the same wave length  :y :y
Wayne has seen the light  :y :y ;)
Welung666
« Reply #118 on: 08 April 2009, 20:09:16 »
Welung 6666
I should be OK for Friday, I'll have to find out off TB what the Vac solenoid problem was first though.
« Reply #119 on: 08 April 2009, 20:10:56 »
What spec is waynes car, does it have climate?
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16   Go Up
