Author Topic: Vacuum tank  (Read 1442 times)
al brown
  • alton, hants
    • Rusty 97 3l estate
Vacuum tank
« on: 05 June 2009, 22:34:55 »
Hi, as above, what is the need for the vaccum tank in the system. I only ask as 1 of the connectors on mine broke so I have just connected the lines in a loop without it for now. What problems, if any will it cause.
Thanks      Al
If it aint broken, you aint trying hard enough
Re: Vacuum tank
« Reply #1 on: 05 June 2009, 22:53:46 »
multiram failure. loss of power, increased fuel economy. have a look in maintenance for a diag if you need it. vac tank from breakers on here, they will probably be along shortly i should think....
http://www.omegaowners.com/forum/YaBB.pl?num=1153840176
« Last Edit: 05 June 2009, 23:00:30 by chrisgixer »
Re: Vacuum tank
« Reply #2 on: 05 June 2009, 23:01:10 »
found diag
al brown
  • alton, hants
Re: Vacuum tank
« Reply #3 on: 05 June 2009, 23:03:07 »
I connected the two ends of the pipes so the system is otherwise complete. Multiramworks but I admit it seems a bit sluggish to open.
So I definately need a new one? is running without it not a good idea then?
Al
Re: Vacuum tank
« Reply #4 on: 05 June 2009, 23:34:10 »
As soon as you open the throttle you have no vacuum, so the multirams stop working. The purpose of the tank is to store the vacuum (if you can store nothing?!?!?) while the throttle is open so the multirams can operate while the engine is under leavy load.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Vacuum tank
« Reply #5 on: 05 June 2009, 23:46:57 »
Al
Think they are about £20 ish from Vauxhall mate iirc :y
Re: Vacuum tank
« Reply #6 on: 06 June 2009, 01:48:27 »
or 5 to 10 from a breaker
al brown
  • alton, hants
Re: Vacuum tank
« Reply #7 on: 06 June 2009, 10:32:37 »
Many thanks guys. Will try and get a wanted ad put up for one.
I checked the car and if you open the throttle quickly the engine splutters and stagnates and the multi-ram doesn't open, if you rev it slowly it works fine and the engine revs freely.
Thanks again,    Al
ally_cover_expert
Re: Vacuum tank
« Reply #8 on: 06 June 2009, 21:50:08 »
Anybody know if the vaccum tank on the 'bagpipes' and the one under the scuttle are both the same?
hotel21
  • The Kingdom of Fife
Re: Vacuum tank
« Reply #9 on: 06 June 2009, 23:44:10 »
They are.....   :y
