Author Topic: Electric Window Problems!  (Read 1185 times)
3.0V6Elite
  • Salisbury
« on: 07 June 2009, 12:08:11 »
Had to disconnect the battery yesterday in order to replace my dodgy alternator. All went well and is back together and running fine.
My problem now is that the electric windows don't go up or down automatically when the button is pressed, you have to keep the button pressed until they are either down or back up, also, the total closure doesn't appear to be operating so you have to close the windows before locking the car.  :(
Any ideas?
Re: Electric Window Problems!
« Reply #1 on: 07 June 2009, 12:15:40 »
Any ideas?
They need re-setting whenever you disconnect the battery. Press & hold the switch when they're at the top for about 4 or 5 secs & you'll hear a click from the motor area. Do it to each window & that's it!  :y
If you have a sunroof that needs re-setting too. Push & hold the switch at closed, tilted & open till all movement stops! It's now re-set!
It's all in the handbook! http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf  ;)  ;)  ;)
« Last Edit: 07 June 2009, 12:18:34 by Andy_B »
3.0V6Elite
  • Salisbury
« Reply #2 on: 07 June 2009, 12:24:59 »
Any ideas?
Cheers Andy, I go and give it a go now!  :y
