Author Topic: Failed water pump. What damage?  (Read 1586 times)
evvo1
« on: 07 June 2009, 13:40:14 »
What damage can be caused if the water pump completely fails whilst travelling? I have a loud rattle from the pulley and obviously need to get it fixed but meanwhile I need to run the car today. If the pump completely fails whilst running would this do any other damage, or would I just have to get it towed in and repaired? Thanks. I've been trying to organise a hire car but this is awful short notice. I need to go at 5:30 this afternoon. (about a 150 mile round trip).
markey mark
  • SLady bitshorpe north lincs
Re: Failed water pump. What damage?
« Reply #1 on: 07 June 2009, 13:58:50 »
if water pump has failed dont use it mate you will cook it !  :(
Boracic
  • Dartford Kent
« Reply #2 on: 07 June 2009, 14:16:14 »
If it breaks up and any part falls onto the cambelt you could end up doing all kinds of damage
evvo1
« Reply #3 on: 07 June 2009, 14:20:21 »
Hi. Thanks for yur reply. The pump hasn't failed as such yet. The engine temp is normal and all is working. It's just that a noise (rattle) has developed that is coming from the the pulley/bearing and it is obviously suffering and therefore needs replacing. I was just wondering what would happen if I risk the journey today and it failed whilst I was travelling, what other damage would ensue? - If it did fail I would obviously stop driving the minute it failed and get it towed in.
markey mark
« Reply #4 on: 07 June 2009, 14:56:20 »
as said potential for bits to fall into cambelt and then bye bye engine  :(
« Reply #5 on: 07 June 2009, 15:09:17 »
As Mark rightly states, "bye bye engine" if you risk travelling with a known faulty water pump.  It is NOT worth the risk! :o :o :o :o ;) ;)
evvo1
« Reply #6 on: 07 June 2009, 15:26:55 »
OK thanks. Sound advice. I've cancelled tonight's gig. I was due to have the cam belt changed in Sept anyway (Pete and Daz), so I might as well bring the whole job forward and get it all done at once. Just trying to contact them now. Thanks again. Better safe than sorry.
jonathanh
  • coventry
« Reply #7 on: 07 June 2009, 17:46:10 »
and are you sure it is the water pump - could be cambelt tensioner disintegrating - don't run it until the problem is fixed
