Author Topic: Hinge Pins  (Read 1251 times)
Colin G
  • West Bridgford, Nottingham
  • I'm a patient man...........usually
    • Omega 2.2 Sport
Hinge Pins
« on: 08 June 2009, 12:13:42 »
Front Drivers door has dropped - can lift and definite wear in the hinges.
Is it just the hinge pins that wear or is more like to be the whole hinge that needs replacing?
Cheers
Col
markey mark
  • SLady bitshorpe north lincs
Re: Hinge Pins
« Reply #1 on: 08 June 2009, 12:28:09 »
try new pins first hinges are welded to doors and pillar  :y
Colin G
    • Omega 2.2 Sport
Re: Hinge Pins
« Reply #2 on: 08 June 2009, 15:03:25 »
Cheers Mark
golden_delicious
  • Kingston upon Hull
Re: Hinge Pins
« Reply #3 on: 08 June 2009, 16:23:44 »
we've got the same prob on the tractor rear n/s door dropped tried new pins with no improvement, has anyone replaced the welded hinges if so how hard is it?
There are only 10 types of people in the world, those who know binary and those who dont ;-)
Re: Hinge Pins
« Reply #4 on: 08 June 2009, 16:34:29 »
How about reaming the 6mm to 1/4" (about 6.35mm) The working part of the pin is a standard roll pin, but with an extra bit to enable them to be easily pulled out.
golden_delicious
Re: Hinge Pins
« Reply #5 on: 08 June 2009, 16:57:13 »
worth a try wonder if you can get oversize pins to save messing about
Re: Hinge Pins
« Reply #6 on: 08 June 2009, 18:16:04 »
The hinge pin is just a variation on a standard roll pin (selloc is another name used for them) If you use an oversized pin ie 1/4" you'll need an oversized hole for them to go into. ;)  ;)
