Author Topic: K63 relay (horn) location?  (Read 1838 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
« on: 19 April 2009, 20:52:06 »
Looking to locate K63.
Fuse17 blown and replacement glowed and blew (~3s).  No horn everything else seems okay. Alarm horn works (think this is a different device).
If Mr Haynes is right and if I've read it right, circuit could be; anyone care to verify?
FV6  feeding F17
F17 feeding   a) K63 relay coil   and   b) horns H18/H48/H2 (are there three?)
K63 coil to   a) S64(a)    and    U28 to S64(b)
S64(a) and S64(b) to earth - sorry, must call it 0v.
Horns to relay contact (NO) to 0v
Where is K63 hiding
What/where is U28 - not listed in my lie book.
Anyone other ideas/previous faults they care to share.
Is K63 the same as anything else I can swap with to prove/eliminate - when found.
-2.5L minifacelift.
« Last Edit: 19 April 2009, 21:05:54 by JohnM »
Re: K63 relay (horn) location?
« Reply #1 on: 19 April 2009, 21:04:33 »
As its not in the engine compartment ..
http://www.omegaowners.com/forum/YaBB.pl?num=1176560725
I'm guessing it must be one of the fuse box ones ...  I'll do a little searching ... :)
« Reply #2 on: 19 April 2009, 22:35:55 »
I had this - turned out to be a faulty horn!!
star_whites
  • Rotherham
« Reply #3 on: 19 April 2009, 22:38:20 »
What year is the car??
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #4 on: 20 April 2009, 20:44:48 »
R reg - 98?
What ought to matter is; 2.5L petrol mini-facelift. Elite. Steering controls for stereo, full ECC, windows in the doors (switches). 'letric everything (except horn!).
Confession mode>
Not been out to check anything since Sunday
/CM
- but not feeling guilty yet as there is noticable lack of ideas so far.
Okay, must check horn connections are intact but anyone spotted K63?
« Last Edit: 21 April 2009, 19:29:07 by JohnM »
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #5 on: 24 April 2009, 12:59:07 »
Thanks dbug - 400Hz horn faulty.
Never did find the relay though, anybody know it's hideout?
ians
  • Reading
« Reply #6 on: 24 April 2009, 13:09:10 »
FV6  feeding F17
Where is K63 hiding
-2.5L minifacelift.
is that correct?  I have a feeling my alarm horn is not working (power sounder is - just), but the normal horn off the steering wheel works fine.
« Reply #7 on: 24 April 2009, 13:09:42 »
Bottom right of the relay box next to the cabin fuse box
« Reply #8 on: 24 April 2009, 13:11:08 »
FV6  feeding F17
Where is K63 hiding
-2.5L minifacelift.
Yep, seperate. Sits next to the power sounder.
ians
  • Reading
« Reply #9 on: 24 April 2009, 13:16:33 »
is there a specific fuse/relay that drives it?
« Reply #10 on: 24 April 2009, 13:22:03 »
Nope, live side is connected to the 80A fuse by the battery and the low side is actuated by the central locking/anti theft ECU.
ians
  • Reading
« Reply #11 on: 24 April 2009, 13:29:52 »
Ah - so most likely the horn is goosed then..
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #12 on: 08 June 2009, 20:23:44 »
Ah yes, must have had my eyes shut!
- late reply but back in the land of the living now.
