Author Topic: rear window stuck down  (Read 1375 times)
golden_delicious
  • Kingston upon Hull
« on: 08 June 2009, 22:52:31 »
The  rear window motor has stopped working unfortunately the window is stuck in the down position ive removed the door panel and membrane but can't see a way to get the window closed as a temp fix any ideas? :'(
There are only 10 types of people in the world, those who know binary and those who dont ;-)
Re: rear window stuck down
« Reply #1 on: 08 June 2009, 23:39:42 »
Is it possible to get to the actual motor connections without going via the contoller? You might be able to put 12v across the motor direct if you can.  :-/  :-/
golden_delicious
« Reply #2 on: 08 June 2009, 23:48:16 »
thanks andy tried that the motor seems dead good idea though cant see what holds the glass in place if i could free it at least i could close the window
« Last Edit: 08 June 2009, 23:48:34 by golden_delicious »
« Reply #3 on: 08 June 2009, 23:58:14 »
The front windows are 'glued' to a rail that's part of the up/down mechanism. The pop rivets need drilling out to remove the motor anyway, so once that's out of the way you could use a tried & tested brush handle to wedge it up!  ;D ;D ;D
golden_delicious
« Reply #4 on: 09 June 2009, 00:32:14 »
glue! that 'l be why it won't shift then i'm gonna block it in till the morning then i'll find a brush handle ;D ;D
thanks andy
