Author Topic: Replacing cam covers  (Read 1195 times)
Bumbazor
  • Worksop
« on: 09 June 2009, 09:52:40 »
When renewing gaskets etc, is there a specific order in which to torque the bolts on each cover?
markfree
Re: Replacing cam covers
« Reply #1 on: 09 June 2009, 15:10:24 »
Spiral pattern working in to out :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 09 June 2009, 15:14:45 »
i think so mate  :y
i always go top left - bottom right - bottom left - top right and so on and i've had no problems  :y
just don't over torque them down or you will twist the cover  :-[ :-[
talking from experance on that one  :'( :'(
Bumbazor
  • Worksop
« Reply #3 on: 09 June 2009, 15:26:25 »
i think so mate  :y
I've got a 2-25Nm torque wrench now, already set to 8!
Will be doing them at the weekend.
