Author Topic: Has my HG gone?  (Read 3119 times)
Bumbazor
  • Worksop
Has my HG gone?
« on: 07 June 2009, 10:21:42 »
I'm getting a steady coolant loss where the level drops by about one inch a week.
The coolant has darkened, and I have mayo in filler neck. The car does mainly short journeys but I think it's more mayo than I should reasonably expect.
I did a pressure test and couldn't find where the coolant was leaking so I replaced the HBV which didn't help, although the old one did have crusty remnants of pink fluid around it.
So, I have new HBV, pressure test doesn't help, dark coolant, and what I think is excessive mayo even for short journeys all week....
Other than HG what can I check?
If it is the HG, is there a genuine kit available or do I have to get all the parts individually?
bluehawk
Re: Has my HG gone?
« Reply #1 on: 07 June 2009, 10:47:03 »
possibly oil cooler ?
Bumbazor
  • Worksop
Re: Has my HG gone?
« Reply #2 on: 07 June 2009, 11:34:44 »
Could be. Would a dodgy oil cooler give rise to my symptoms?
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Has my HG gone?
« Reply #3 on: 07 June 2009, 11:38:33 »
I had an awful lot of mayo in the filler neck just from short journeys, was a bit surprised by the amount and thought HG but appears not!
A long run usually clears it, would be unusual for HG to have gone IMHO.
Bumbazor
  • Worksop
Re: Has my HG gone?
« Reply #4 on: 07 June 2009, 11:45:18 »
Yes but its not just mayo that that is a problem. My other symptoms are causes for concern too, and I think my mayo is excessive. I've had a couple of 400 mile runs in the past two weeks; neither cleared the mayo much.
Re: Has my HG gone?
« Reply #5 on: 07 June 2009, 15:38:10 »
Is your coolant oily? If so suspect oil cooler.
Try cleaning out your breathers.
Re: Has my HG gone?
« Reply #6 on: 07 June 2009, 15:52:18 »
Yep, same here has to be cleaned every 6 months or so. Loads gets in there.
Re: Has my HG gone?
« Reply #7 on: 07 June 2009, 16:08:16 »
a compression test with a cold engine will give more idea.. :y
ScottieMV6
  • Swinton, Manchester
Re: Has my HG gone?
« Reply #8 on: 07 June 2009, 17:01:34 »
Sounds like oil cooler. Is the coolant greasy (as if it has oil in it)?
Just done mine with similar symptoms.  :y
I'd rather be scared to death than bored to death!!
Bumbazor
  • Worksop
Re: Has my HG gone?
« Reply #9 on: 07 June 2009, 17:23:01 »
Thanks for your replies. Here are mine:
dbug; coolant certainly looks a lot darker than the bright pink it was. If it's not oil I don't know what else it could be. I flushed the system a week ago when I changed HBV so I don't think it's a general build up of muck.
LSG 1; My mayo needs cleaning a lot more frequently than 6 months!
cem; I've no idea how to do a compression test...
scottie7275; I haven't checked it but that's a good point which I will check up on later...
star_whites
  • Rotherham
Re: Has my HG gone?
« Reply #10 on: 07 June 2009, 20:19:36 »
Has the oil got any sign of water in it when you remove the dipstick. If not the question has to be where is the water leaking too.
I have a pressure cap and a compresion tester you can borrow Tom. I can even write you instructions on how to use them if you need them.
The pressure cap will enable you to presurise your water system when the plenum and injection manifold is removed without the need to run your engine. That should hopefully show you where the water leak is. The compresion tester will tell you if you have compresion down on any cyclinders.  :y :y
Bumbazor
  • Worksop
Re: Has my HG gone?
« Reply #11 on: 07 June 2009, 20:50:32 »
That would be great, and I could pick up my cam locking kit at the same time!
I could get to you after work on Tuesday... PM for more info.
star_whites
  • Rotherham
Re: Has my HG gone?
« Reply #12 on: 07 June 2009, 21:23:10 »
Ok Tom, tuesday would be best for me as well. Will drop you a pm with address.
Bumbazor
  • Worksop
Re: Has my HG gone?
« Reply #13 on: 10 June 2009, 08:13:42 »
Yes it is. Was with star_whites yesterday and he thought the same, although there is no mayo on the dipstick.
I will be checking the oil cooler this weekend and will replace as necessary when I get the bits I need.
ScottieMV6
Re: Has my HG gone?
« Reply #14 on: 10 June 2009, 08:18:16 »
There was no mayo on my dipstick either mate. (ooh err) ;D
Hopefully new oil cooler will sort the problem. Make sure you flush the coolant out loads!  :y
« Last Edit: 10 June 2009, 08:18:40 by scottie7275 »
