Author Topic: Great Start  (Read 1107 times)
rangerman
  • Manchester
Great Start
« on: 10 June 2009, 18:03:53 »
Already, got home tonight & have clear fluid leaking from some
Pipe/pipes behind the driver’s side front headlamp? any ideas please.    >:(
Bumbazor
  • Worksop
Re: Great Start
« Reply #1 on: 10 June 2009, 18:54:16 »
Possibly coolant. It should be pink but small amounts and drips can look clear sometimes.
Can you identify the pipe it is leaking from?
rangerman
  • Manchester
Re: Great Start
« Reply #2 on: 10 June 2009, 19:22:16 »
it's not a small leak when I start the engine, it seems to pour out, just under the air book there are two pipes, & the hose that go in to the radiator, it coming from that region..
