Author Topic: symptoms and visual clue re fried dispack  (Read 1145 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 09 June 2009, 17:23:28 »
hi all
if a cam cover leak has buggered your HT leads, is there a way of knowing if your dispack has suffered too? what are the symptoms and if looking at the dispack are there any visual cues?
juddering or misfire can be caused by knackered leads but wasnt sure of dispack symptoms.
ta
PM with your requests.
Varche
  • middle of Andalucia
    • Golf Estate
Re: symptoms and visual clue re fried dispack
« Reply #1 on: 09 June 2009, 17:35:35 »
Well on my V6 I tried all the relatively easy things to do like change the plug leads and spark plugs (made no difference) still got a misfire at about 50 mph or under load. I had had leaking cam cover problem.
When I got the DIS pack off it was quite badly corroded underneath. Maybe the HeaterBypassValve had been leaking onto it over years. New one instantly cured the problem.
varche
humbucker
  • Cambridgeshire
« Reply #2 on: 09 June 2009, 22:45:05 »
well it's the drivers side cam cover that i've got a leak so hopefully that's an inch or two out of the way of the dispack and worst case scenario is just leads, plugs and cam cover gasket... sheesh... such a pain to get to that side as well...
« Reply #3 on: 10 June 2009, 00:07:18 »
Driver side is much easier than the 246 bank!
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4 on: 10 June 2009, 08:59:30 »
any sign of rust underneath the diss pack and i would treat it as suspect mate.
i've a bosch one here off my old 97 v6.
oval type LT plug.
pm me if i can help  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 10 June 2009, 09:04:21 »
If you have not got a trade card, i got a set of ht leads off flea bay.  ( can dig out the address if needed )
good length and nice tight fit  :y
Offer price was £21 delivered
« Reply #6 on: 10 June 2009, 09:11:28 »
changed the dis eventually on another members car. He was out of work but needed the car for his hospital appointments. Money was very tight so we started with the cheapest first. The plugs, in changing those it was obvious the leads where shagged. One even fell apart, or was damaged by previous work, they had an oil tide mark from previous blown cam cover gaskits which had been repaired by someone. But the breathers where still partly blocked so did those.
So, to answer your q, with plugs and leads changed there was a slight improvement but the car still misfired. But it sounded like a subaru flat four and hardly any vibration. This was different to my old 2.5 that had buggerd leads, my car sounded terrible with a very bad vibration. It was leaping from side to side violently. Why?
Well my car had a missfire on 2 cylinders on the same bank causing a bad inbalance in the firing order, with the two opposite good cylinders throwing the engine to one side each time they fired and the two bab cylinders not firing to oppose or balance the good ones the engine was jumping to the left and right on its rubber engine mounts.
The failed dis did not give this bad vibration, and sounded and looked quite smooth although like a scooby as said. It was badly down on power and fuel consumption was through the roof. On removal of the dis pac, there was nothing else left to change on the ignition system, it was obvious on its base that it had split and the iron core had rusted badly. It and the rear area of the engine where covered in orange residue probably from the hbv which was cable tied on rather that sloted on to its post as normal . The scuttle also had a bit of a leak as the rain was dripping through the join in that area which probably didnt help the dis either. With the dis removed(had to remove the wiper motor as well as the scuttle and plenum, a long bendy screw driver helps or a quarter inch drive with extension and "woggle") it showed the firing order and correct plug connections printed on the top.
With help from the forum and going by the symptoms we realised that the dis fires two cylinders each from 3 cores. If one core fails, as in this case (the non plug end one), you loose two cylinders one on each bank. So the firing order is still balanced, no or little vibration. Thats my experience anyway.
Bit long winded but hth.
humbucker
  • Cambridgeshire
« Reply #7 on: 10 June 2009, 21:16:41 »
thanks for all your advice people. the orange trace sounds like a good one to look out for. ive not long changed the plugs and the cam covers were done when the head gaskets were done. i suspect that they were done up too tight or something similar and have leaked causing the ht leads to drown or something. but i thought i'd check to see if it was a possible DIS issue too and if so what i could look out for.
i am also rather absent minded and when i said it was the drivers side i meant to say passenger side. *groan*
i'll let you know how i get on...
