Author Topic: Ebay head bolts  (Read 1544 times)
Martin_1962
Ebay head bolts
« on: 10 June 2009, 21:39:04 »
WHo is recommended as the one I used before is on holiday?
shammster
  • Essex, UK
Re: Ebay head bolts
« Reply #1 on: 10 June 2009, 22:19:46 »
Don't know about recommended but just got a full engine set from shirley9293
One head is on fine and torqued down
eBay Item: 310118373163
Steve.
So many cars to fix, oh well open the beer!
Re: Ebay head bolts
« Reply #2 on: 11 June 2009, 08:20:08 »
The ones from 'shirley' are shite.
I have had them a few times and the quality is poor and a few snapped on me (I have photos of the poor quality!).
I now use 'Trechii' as they are good quality and well priced.
In the 'shirley' head kits be aware that the following parts are pretty useless:
Cam cover seals and O rings
Cam seals (1 in 4 will leak, re-use the old ones)
Dowty washers (just a poor fit)
Exhaust manifold gaskets (nasty composite items)
Inlet seals (poor fit and poorly made, not really requried anyway)
In fact, the only decent items are the Elring head gaskets and the stem seals!
« Last Edit: 11 June 2009, 08:20:58 by Mark »
Re: Ebay head bolts
« Reply #3 on: 11 June 2009, 08:25:38 »
You wouldn't recommend them then?  ;) ;) :y
Re: Ebay head bolts
« Reply #4 on: 11 June 2009, 08:31:02 »
Poorly formed wavey threads
Generally just shite quality
shammster
  • Essex, UK
Re: Ebay head bolts
« Reply #5 on: 11 June 2009, 15:37:33 »
Oh bugger  >:(
Will check the other set and then deciede if the head has to come off again.
Nothing is ever simple is it.
Mutter, mutter, mutter  :-/
Re: Ebay head bolts
« Reply #6 on: 11 June 2009, 15:54:50 »
Oh lord. I wonder which ones autovaux gave me  - they're not branded  :-X
shammster
  • Essex, UK
Re: Ebay head bolts
« Reply #7 on: 11 June 2009, 15:57:18 »
Will take a pic of the packaging tonight and post here.
Think it's fairly plain plastic bags.
Re: Ebay head bolts
« Reply #8 on: 11 June 2009, 16:05:37 »
I say let sleeping dogs lie. More likely to come a cropper when being torqued-up or removed. If they've survived being torqued up my personal view would be to leave them. Worst that can happen is that one fails, head gasket goes and it's no worse than head-off anyway at that point.
shammster
  • Essex, UK
Re: Ebay head bolts
« Reply #9 on: 11 June 2009, 16:21:06 »
There is alot to be said for if it ain't broken don't fix it.
Especially as it's been of the road for a month and I JUST WANT TO DRIVE IT AGAIN !!!
shammster
  • Essex, UK
Re: Ebay head bolts
« Reply #10 on: 11 June 2009, 17:21:50 »
Have looked at the bolts and they good ok, no wavy threads.
Phew!
Here's the bag they came in.
Martin_1962
Re: Ebay head bolts
« Reply #11 on: 11 June 2009, 19:13:11 »
Trechii is on holiday :( and I don't think 135 will last that long and £3.50 each is a bit much
Martin_1962
Re: Ebay head bolts
« Reply #12 on: 11 June 2009, 19:13:58 »
MAy have to Autovaux then
