Author Topic: Engine/box Change Issue  (Read 1836 times)
AndyVXR300
« on: 10 June 2009, 22:26:48 »
When i had my Omega converted from 2.5 to 3.0 the person who done this used the Gearbox ECU from the 2.5 hence it still has a AR25 ECU.
I had an issue where i kept getting Gearbox fault coming up so decided to have it checked out and was told it should of have had the proper AR35 ECU fitted at the time of the conversion.
So can anyone clarify this ??
I have 2 AR35 ECU'S sitting around so no issues there just want to know :y
The gearbox fault has not appeared for over a week now by the way.....
Andy
« Last Edit: 11 June 2009, 19:44:09 by biggshome »
WWW.VXRONLINE.CO.UK
Re: Engine/box Change Issue
« Reply #1 on: 11 June 2009, 08:33:26 »
So you now have a stressed AR25 fitted or an AR35 with unknown history fitted?
The ECU's are the same for both engine types by the way
AndyVXR300
« Reply #2 on: 11 June 2009, 19:43:27 »
Changed the oil in the gearbox (AR35)today and had the ecu updated on tech 2 and it is now 100%.... :y
WWW.VXRONLINE.CO.UK
MutantCav
  • Gainsborough
« Reply #3 on: 11 June 2009, 21:29:51 »
Was going to say more likely to be fluid mate...
