Author Topic: Slipping Automatic gearbox  (Read 1476 times)
plumber
« on: 11 June 2009, 12:46:20 »
Hi im a newbie this is my first post.
I have a 2.5 v6 vauxhall omega automatic  touer estate .
The problem i have is that the gearbox is  slipping
I have  been advised to check the fluid level which i have done and replaced with lucas transmission fluid .
I have also been advised that it can be caused by the selector switch ,Which i have checked .
Does anyone know what other faults may cause  this problem
Thanks Tony.
Varche
  • middle of Andalucia
    • Golf Estate
Re: Slipping Automatic gearbox
« Reply #1 on: 11 June 2009, 13:01:35 »
Hi welcome to the site.
When you say you replaced the fluid with Lucas transmission fluid was that a Dexron111 type?
Also when you checked the level afterwards did you do it with the gearbox warm and on the level and run through the gears while you watch the drain plug hole?
Any wierdness on the lights alongside the gearlever?
varche
plumber
« Reply #2 on: 11 June 2009, 15:03:37 »
Thanks for the reply it now appears to be caused the  Gear lever selector position switch -part number 96017511 ,does anyone know where i can buy this online , the main dealer is too expensive
Thanks Tony
Bumbazor
  • Worksop
« Reply #3 on: 11 June 2009, 15:14:45 »
You will probably find someone here who has a secondhand one or is breaking a car with one. Check in the 'Parts for Sale and Wanted' section.
plumber
« Reply #4 on: 11 June 2009, 15:47:12 »
Thanks again for the reply is there a step by step guide on how to remove the gear selector switch on the geabox clean and refit on this site
Thanks Tony
Richard A
  • Aldridge, West Midlands
« Reply #5 on: 11 June 2009, 17:50:23 »
What Lucas Fluid ? It should only be Dexron lll ? How much ? How did measure if it was the correct amount ?
regards
richarda
richard a
plumber
« Reply #6 on: 11 June 2009, 22:18:22 »
the transmission fluid used was lucas used as an addative with the correct oil by my garage
Quote from there site "Lucas Transmission Fix stops slip, hesitation and rough shifting in worn transmissions and completely eliminates most seal leaks. An excellent preventative maintenance product. Use also in light duty manual transmissions to increase shifting ease and transmission life.
Contains no solvents
Lowers operating temperatures and stops foaming
Can be added to existing fluid without draining any out
Effective in an extremely high percentage of cases
Lucas Transmission Fix has a polymetric film which renews worn bands to stop slipping. It cleans and lubricates sticking valves for proper shifting and controls heat and foaming. This product will extend fluid life up to three times longer. It completely stops most seal leaks and results are usually immediate. It is the perfect preventative maintenance product to stop initial wear in newer transmissions, and is a must for motor homes, towing vehicles and all other hard working transmissions. Compatible with all transmission fluids. Will not void new car warranties and contains no harmful solvents."
Thanks Tony
sassanach
  • trowbridge
« Reply #7 on: 11 June 2009, 22:22:14 »
NO OFFENCE MATE, BUT ONE OFF THE BEST LAUGHS I HAVE HAD IN AGES ;D ;D BUT SERIOUSLY WHERE ARE YOU?
sassanach
  • trowbridge
« Reply #8 on: 11 June 2009, 22:23:30 »
WHOOPS  caps lock not intended(to much guiness,)
plumber
« Reply #9 on: 12 June 2009, 13:34:52 »
I take it you dont rate there product then?
This was mixed with dexron 111 oil
Tony
cornwall
« Last Edit: 12 June 2009, 13:37:56 by plumber »
sassanach
  • trowbridge
« Reply #10 on: 12 June 2009, 13:50:36 »
its like a lot of "miracle"cures in a bottle ie slick 50,air con additive,molyslip,redex etc.anyway exactly what do you mean by "slipping"
Page created in 0.028 seconds with 16 queries.
