Author Topic: autobox oil and filter  (Read 1244 times)
gazsomega
  • midlands
    • 2.5 Opel estate
« on: 13 June 2009, 00:03:29 »
ok ive spent the last hour looking for how to change oil and filter on a auto box.
this is the first auto i have owned.ive read varouis things on here as to what i need to do remove the sumps and change filter and refit.
ok but what i need to no is ware will this filter be and will i see it and is there just one.
will i get the gasket and oil and filter from someware like halfrauds or will i have to use an auto supplier like listed on here
i will be in the pit all day tommrow changing my diff so im going to do my auto box oil
any tips will be great
Used  to have  two v6 and they roared
Now got 2.5 to Opel
Re: autobox oil and filter
« Reply #1 on: 13 June 2009, 00:19:31 »
The best place to get the filter/gaskets from is jpat
http://www.jpat.co.uk
How to check the fluid level :
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
AFAIK ... the sequence is as follows (not done it yet .. but have got the bits .... )
With car as high as possible and as level as possible
Remove fill/level plug - ATF WILL run out.
With a syphon tube/ suction tool/whatever, remove as much ATF as you can via the fill/level point
Undo the bolts on the large sump almost to the point of release, when ready remove all bolts but the 4 corners
Supporting the sump remove the last 4 bolts, the sump will be heavy and awkward as it is full of ATF. Dispose of old ATF
Remove the small sump in a similar fashion
The filter will be readily visible held on by just one screw, remove and either clean or replace.
Clean the faces of both the gearbox and both sumps of ALL traces of old gasket, this can be difficult and time consuming
Once clean replace both sumps using new gaskets.
Follow the procedure at the  top to fill with new ATF.
You WILL spill ATF and it WILL drip on you as you do the filter and clean the sump mounting face on the gearbox.
It WILL stink and you WILL have trouble getting it out of your hair.
As I say, I've not yet done it, but this is the list I have built up having read other peoples reports over the past while.
If it is wrong hopefully someone who "knows" will correct it, and we'll both be able to do the job properly.
It is my intention to try and write a "how-to" with pictures when I do the job, my problem is getting the car level, as soon as I work out how to do that and get under it I shall be doing this job !!
HTH
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #2 on: 13 June 2009, 00:30:34 »
well i have a pitt you can use to do yours in and take pictures and make a guide and at the same time we could do mine thats if you want to travel to me but the car would be level and its easy to work under if not thanks for the help
Now got 2.5 to Opel
« Reply #3 on: 13 June 2009, 01:17:04 »
I didn't!  ;) ;) ;) But I did spill ATF on  my drive when my fill tube came out of the side of the box when filling!  ;D ;D ;D  :y  :y  :y
