Author Topic: 800rpm idle  (Read 2948 times)
Martin_1962
800rpm idle
« on: 09 June 2009, 17:38:48 »
OK What do I check please?
no fault codes now
Re: 800rpm idle
« Reply #1 on: 09 June 2009, 18:57:27 »
Thats normal isn't it ? With heaters off I suppose you mean?
AndyVXR300
Re: 800rpm idle
« Reply #2 on: 09 June 2009, 18:58:45 »
no fault codes now
Mines about 650 on start up and drops to about 550 after she has warmed up :y
WWW.VXRONLINE.CO.UK
Re: 800rpm idle
« Reply #3 on: 09 June 2009, 19:12:36 »
no fault codes now
Yup same here, with heaters on it's just below 1k rpm :y
Re: 800rpm idle
« Reply #4 on: 09 June 2009, 19:36:53 »
Air leak
Martin_1962
Re: 800rpm idle
« Reply #5 on: 09 June 2009, 20:24:20 »
Air leak
Thought so but can't hear any hissing
Vac hoses are all on too
Re: 800rpm idle
« Reply #6 on: 09 June 2009, 20:38:17 »
Air leak
Spray around lightly with carb cleaner while the engine is running ... any engine note change is where the carb cleaner is being sucked in and burned...
After fixing wipe down with paper towel ... result ... fixed air leak and a nice clean engine  ..  :)
Re: 800rpm idle
« Reply #7 on: 10 June 2009, 00:17:21 »
Air leak
Never thought of that method - but why not eh  ;D
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: 800rpm idle
« Reply #8 on: 10 June 2009, 01:31:10 »
Aircon on or off?
TuBy's new whipping boy.
Martin_1962
Re: 800rpm idle
« Reply #9 on: 10 June 2009, 17:54:15 »
On
Will be spraying once I have bought something
Re: 800rpm idle
« Reply #10 on: 10 June 2009, 18:14:05 »
On
Thats normal isn't it?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: 800rpm idle
« Reply #11 on: 10 June 2009, 18:39:24 »
On
According to "My Naff Code Reader" mine requests 850 rpm idle when warmed up with aircon on, 750 rpm aircon off.
Martin_1962
Re: 800rpm idle
« Reply #12 on: 10 June 2009, 21:38:39 »
Used to idle about 650 or so
serek
  • huntingdon
    • 3.2 mv6
Re: 800rpm idle
« Reply #13 on: 10 June 2009, 21:40:27 »
On
same on mine  :-?
Martin_1962
Re: 800rpm idle
« Reply #14 on: 11 June 2009, 21:38:15 »
At 4000 rpm it was very juddery. Did a quick look, multiram pipe had fallen off under the throttle body
