Author Topic: Sometimes difficult to start  (Read 1649 times)
Martin_1962
« on: 16 June 2009, 18:49:35 »
Compression OK, cam timing OK, may be a small air leak on the inlet - will fix when the 135 head gasket is replaced.
Have to use some throttle to start and it wizzes on the starter motor.
Would this be the start of crank sensor failure?
Martin_1962
Re: Sometimes difficult to start
« Reply #1 on: 16 June 2009, 18:49:59 »
BTW this is sometimes - usually starts easily
The Cambelt Kid
  • Derby
« Reply #2 on: 17 June 2009, 00:10:14 »
Sounds like the crank sensor to me.  I didn't think of this when mine started to fail, but i soon realised!
About £40 notes AFAIR
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
hotel21
  • The Kingdom of Fife
« Reply #3 on: 17 June 2009, 00:23:14 »
codes?  Really need to explore that first, wouldn't you agree??
Martin_1962
« Reply #4 on: 17 June 2009, 07:52:33 »
No new codes
« Reply #5 on: 17 June 2009, 08:32:03 »
mine had a few episodes(4?) like this last year on really hot days parked up in the sun. Long crank on the key and a bit of a spltutter. No codes, not happened again since. Strange. Yours sounds a bit more regular though...?
« Reply #6 on: 17 June 2009, 08:41:34 »
Sometimes happen to me also in hot days although the cranksensor is brand new (vx-so is cam sensor)..
I think either the fuel comes late or is too much :-/
and deffo no eml light..
« Last Edit: 17 June 2009, 08:42:05 by cem_devecioglu »
« Reply #7 on: 17 June 2009, 12:20:51 »
thankyou cem, you reminded me, God my memory is crap. I have a tendency to put the key in and turn straight away, starting the engine before all the dash lights have gone out. Nothing unusual possibly, but a friend has a Lexus is 300 that is quite bad in this reguard. The fix is simply to allow the dash lights to go out, which gives the fuel pump enough time to prime the injectors and away it goes no problem. Apparently its been fine since following this rule.
Testing this theory on the omega when it only happens a few times a year will be difficult i guess and may not be part of the problem anyway. Who knows...?
But in Martins case if its unusual for his car and considering all the work done recently, i might be checking inlet and fuel etc.
Martin_1962
« Reply #8 on: 17 June 2009, 18:33:32 »
Fuel - hmm
Well I should be having a visitor this weekend who can help me
« Reply #9 on: 17 June 2009, 20:54:56 »
 :) :y
